Choppy video playback
Postby grheard » Fri Nov 04, 2011 7:03 pm
Problem Description: (A clear description of the problem including any error messages that you received in your playback application)
Choppy video playback (buffering)
Troubleshooting Steps: (A list of the steps you have taken to try to solve this problem yourself)
Ran fiddler and found the following...
14:53:04:3726 fiddler.network.streaming> Streaming of response #189 to client failed: An established connection was aborted by the software in your host machine
14:53:04:3736 fiddler.network.streaming> Streaming of response #189 to client failed: An established connection was aborted by the software in your host machine
14:53:04:9337 fiddler.network.streaming> Streaming of response #189 to client failed: An established connection was aborted by the software in your host machine
14:53:04:9377 fiddler.network.streaming> Streaming of response #189 to client failed: An established connection was aborted by the software in your host machine
14:53:05:5197 fiddler.network.streaming> Streaming of response #189 to client failed: An established connection was aborted by the software in your host machine
14:53:05:5307 fiddler.network.streaming> Streaming of response #189 to client failed: An established connection was aborted by the software in your host machine
14:53:05:5337 fiddler.network.streaming> Streaming of response #189 to client failed: An established connection was aborted by the software in your host machine
14:53:06:0488 fiddler.network.streaming> Streaming of response #189 to client failed: An established connection was aborted by the software in your host machine
14:53:06:0538 fiddler.network.streaming> Streaming of response #189 to client failed: An established connection was aborted by the software in your host machine
14:53:06:6638 fiddler.network.streaming> Streaming of response #189 to client failed: An established connection was aborted by the software in your host machine
14:53:06:6718 fiddler.network.streaming> Streaming of response #189 to client failed: An established connection was aborted by the software in your host machine
Playback Application and version: (The end application that you are using to stream from Subsonic)
Using the built in java video player on the subsonic webpage. The browser is firefox 8 beta.
Subsonic Version: (copy/paste from the "About" screen in the Subsonic Web Interface)
Server Version: (copy/paste from the "About" screen in the Subsonic Web Interface)
About Subsonic
Version 4.5 (build 2384) – August 10, 2011
Server jetty-6.1.x, java 1.6.0_20, Linux (44.2 MB / 91.6 MB)
Hardware Platform: (Windows, Mac, Linux, NAS Model, etc... Invclude version if applicable)
The server is a Core2Duo @ 2.6GHz running on a P5N32-E motherboard with 4GB of memory running Ubuntu 11.04 server.
Java Memory Limit: (Windows: found in the Subsonic Agent in the taskbar)
I set /etc/default/subsonic to use 256Mb. If your talking about something else I don't understand.
Problem Filename: (If you are having difficulty with a particular file, please include it's name)
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
No particular file problem. Seems to happen on a lot of videos.
Last ten log file lines: (The last ten or so lines copied and pasted from the About screen in the Subsonic Web Interface. Ideally these will be in a CODE block as well.)
[11/4/11 2:26:03 PM EDT] INFO PlaylistInputStream admin listening to "Season 4/Torchwood.S04E02.HDTV.XviD-LOL.[VTV].avi"
[11/4/11 2:26:03 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [4] [-i] [/usr/local/backup/media/movie/Torchwood/Season 4/Torchwood.S04E02.HDTV.XviD-LOL.[VTV].avi] [-async] [1] [-b] [400k] [-s] [426x240] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-]
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) FFmpeg version SVN-r0.5.1-4:0.5.1-1ubuntu1.2, Copyright (c) 2000-2009 Fabrice Bellard, et al.
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) configuration: --extra-version=4:0.5.1-1ubuntu1.2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavutil 49.15. 0 / 49.15. 0
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavcodec 52.20. 1 / 52.20. 1
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavformat 52.31. 0 / 52.31. 0
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavdevice 52. 1. 0 / 52. 1. 0
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libavfilter 0. 4. 0 / 0. 4. 0
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libswscale 0. 7. 1 / 0. 7. 1
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) built on Sep 16 2011 17:08:44, gcc: 4.4.3
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Input #0, avi, from '/usr/local/backup/media/movie/Torchwood/Season 4/Torchwood.S04E02.HDTV.XviD-LOL.[VTV].avi':
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Duration: 00:53:43.51, start: 0.000000, bitrate: 1431 kb/s
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0: Video: mpeg4, yuv420p, 624x352 [PAR 1:1 DAR 39:22], PAR 180224:180219 DAR 8192:4621, 23.98 tbr, 23.98 tbn, 23.98 tbc
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 124 kb/s
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream mapping:
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Stream #0.1 -> #0.1
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) Press [q] to stop encoding
[11/4/11 2:26:04 PM EDT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) [mp3 @ 0x1bf90a0]mdb:44, lastbuf:0 skipping granule 0
grheard
Users browsing this forum: Google [Bot] and 23 guests
