Web player won't play songs
Postby rothgar » Mon Nov 07, 2011 6:49 am
Problem Description: When playing a song from the web player the loading bar fills up (buffer) and the song plays for about .1 sec and then is silent. The logs show that I'm still playing the file but the player icon turns back as if I weren't playing the song. If I skip forward in the song it plays just fine. Subsequent files in a playlist may or may not play automatically. With any file I can skip forward in the song and it will play to completion.
Troubleshooting Steps: upgraded from subsonic 4.4 to 4.6b1
Playback Application and version: web-based player in Windows 7 x64. Tried with Google Chrome 13.0 and Mozilla Firefox 6.0
Subsonic Version: 4.6.beta1 (build 2508) – November 1, 2011
Server Version: jetty-6.1.x, java 1.6.0_20, Linux (47.1 MB / 72.7 MB)
Hardware Platform: HP Media smart server running Amahi Linux
Java Memory Limit: 256 (changed in config file and restarted service)
Problem Filename: Any music file.
Output from ffmpeg -i:
FFmpeg version 0.6.3-rpmfusion, Copyright (c) 2000-2010 the FFmpeg developers
  built on May  5 2011 19:19:44 with gcc 4.5.1 20100924 (Red Hat 4.5.1-4)
  configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib --mandir=/usr/share/man --arch=i686 --extra-cflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m32 -march=i686 -mtune=atom -fasynchronous-unwind-tables' --extra-version=rpmfusion --enable-bzlib --enable-libdc1394 --enable-libdirac --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid --enable-x11grab --enable-avfilter --enable-postproc --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib --cpu=i686 --enable-runtime-cpudetect
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
[mp3 @ 0x850dab0]Header missing
[mp3 @ 0x850c880]max_analyze_duration reached
[mp3 @ 0x850c880]Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from '/var/music/M.I.A/M.I.A. - 2007 - Kala/M.I.A. - Kala - 11 -Paper Planes.mp3':
  Metadata:
    TIT2            : Paper Planes
    TRCK            : 11
    TYER            : 2007
    TCON            : Hip-Hop
    TALB            : Kala
    TPE2            : M.I.A.
    TPOS            : 1/1
    TCOM            : Diplo/M.I.A.
    TPE1            : M.I.A.
  Duration: 00:25:43.56, start: 0.000000, bitrate: 32 kb/s
    Stream #0.0: Audio: mp3, 44100 Hz, 2 channels, s16, 32 kb/s
Last ten log file lines:
[11/6/11 10:32:10 PM PST]    INFO   PlaylistInputStream   admin listening to "Moby - 2005 - Hotel/Moby - Hotel - 11 - Love Should.mp3"
[11/6/11 10:32:12 PM PST]    INFO   PlaylistInputStream   admin listening to "Moby - 2005 - Hotel/Moby - Hotel - 12 - Slipping Away.mp3"
[11/6/11 10:32:13 PM PST]    INFO   PlaylistInputStream   admin listening to "Moby - 2005 - Hotel/Moby - Hotel - 13 - Forever.mp3"
[11/6/11 10:32:13 PM PST]    INFO   PlaylistInputStream   admin listening to "Moby - 2005 - Hotel/Moby - Hotel - 14 - Homeward Angel.mp3"
[11/6/11 10:40:14 PM PST]    INFO   PlaylistInputStream   rothgar listening to "M.I.A. - 2007 - Kala/M.I.A. - Kala - 11 -Paper Planes.mp3"
[11/6/11 10:43:30 PM PST]    INFO   PlaylistInputStream   rothgar listening to "MGMT - Oracular Spectacular/MGMT -02- Weekend Wars.mp3"
Any help in getting this fixed would be appreciated. Thanks!
rothgar
Re: Web player won't play songs
Postby BKKKPewsey » Mon Nov 07, 2011 2:06 pm
When you say any music file do you mean only mp3's or other file types too?
Did it work ok in v 4.4?
One thing to try is to create another player and try that.
Postby rothgar » Mon Nov 07, 2011 5:31 pm
I have only tried mp3s (will try another format tonight).
It did not work in 4.4
I'll also try from an external player tonight.
rothgar
Postby BKKKPewsey » Mon Nov 07, 2011 5:45 pm
BKKKPewsey wrote:One thing to try is to create another player and try that.
Sorry not over clear I mean create another web player via settings/players - clone player
remember to select your web player in drop down list first.
Postby lahaso » Wed Nov 09, 2011 12:07 am
I got the exactly same problem. This happened maybe a couple of times each day before, with the older versions of Subsonic.
But with the new beta-release it happens on 1 out of 5 songs, which is very annoying.
I've tried to make a new player, but it ends with the same result.
It would be great if someone know a way to solve this :)
lahaso
Postby rothgar » Fri Nov 11, 2011 5:08 am
I can't figure out how to play/find my non-mp3 songs. I have a bunch of flac files but they don't show up in the main interface.
The files play just fine in an external player (once downloaded)
I played 7 songs (and counting) tonight with no issue. I'll keep my eye out for a new beta and install it once the new release comes out.
rothgar
Postby BKKKPewsey » Fri Nov 11, 2011 6:29 pm
rothgar wrote:I can't figure out how to play/find my non-mp3 songs. I have a bunch of flac files but they don't show up in the main interface.
Make sure the file types are entered in settings/general - music files
