Can't fastforward
Can't fastforward
Postby maciekmiszkiel » Thu Nov 10, 2011 10:56 pm
This is a reoccurring issue in my case.
Out of a sudden when I play my .mp3 not even other formats on the external player I cannot fast forward them.
I've selected "External Player with Playlist" option but that still does not work for me. I've also tried cloneing and creating a new player with no effect.
Not sure if I should just reinstall it which is kinda cumbersome since it happens quite often or if anyone knows any trick to fix that.
Help would be appreciated.
maciekmiszkiel
Re: Can't fastforward
Postby BKKKPewsey » Fri Nov 11, 2011 1:29 am
Knowing what external player you are using might help us
Postby maciekmiszkiel » Fri Nov 11, 2011 4:02 am
It happens on multiple ones. So far I tried windows media player and winamp.
maciekmiszkiel
Postby BKKKPewsey » Fri Nov 11, 2011 10:47 pm
To make sure we are talking about the same thing, when you say fast forward, do you mean next (previous) track?
Postby maciekmiszkiel » Mon Nov 14, 2011 11:03 pm
No, I meant fast forwarding every 5 sec. or so. You can do that in WinAmp by using arrow keys. It used to work before but recently broke again.
maciekmiszkiel
Postby BKKKPewsey » Tue Nov 15, 2011 12:03 am
Ok now we finally have finally found out what you are referring to.
I have just checked with my winamp player using external with playlist and it skips forward or back 5 secs no problem.
Does it work if you play a track directly in winamp?
also does the seek bar (seeker) operate on yours?
Postby maciekmiszkiel » Tue Nov 15, 2011 12:43 am
Yeah, everything works if I'm playing local media. The seekbar doesn't even show up for me when I stream from subsonic. It's not computer related as I tried it from a few different machines.
maciekmiszkiel
Postby BKKKPewsey » Tue Nov 15, 2011 2:06 am
Hmm! odd
Can you post some more details of your setup eg server OS, SS version etc
and also your winamp version.
maciekmiszkiel wrote:It's not computer related as I tried it from a few different machines
I think you find it will be but which one :?
I cannot see it being a SS bug because its working ok for me (but I don't usually use winamp)
Note my SS version is 4.6beta and winamp V5.621
Postby maciekmiszkiel » Tue Nov 15, 2011 7:00 pm
I'm running
Version 4.6.beta1 (build 2501) – November 1, 2011
Server jetty-6.1.x, java 1.6.0_29, Windows 7 (18.7 MB / 34.8 MB)
My OS is Win & Ultiomate 64bit
Winamp is 5.621
Like I mentioned before though I can replicate this issue on Windows Media Player as well. When it worked properly it worked on both of them.
maciekmiszkiel
Postby maciekmiszkiel » Tue Nov 15, 2011 7:03 pm
I'm taking it back. Just a minute ago I've updated to the version that I reported in the previous post. Seems like it's working now. I bet that if I installed it all over again that this would resolve the issue. I'm not sure why it happens every now and then. How can I forward a log that someone could examine ?
maciekmiszkiel
