2 very annoying bugs on subsonic Android client
Postby legluondunet » Sat Nov 12, 2011 2:59 pm
I have two problems on the subsonic Android client:
1) subsonic no more cut audio when Google maps navigation's talking. It's a very annoying bug!
2) subsonic android cient sometimes does not exit correctly, so I have to kill it with a task manager, but it is sometimes not enough, best soluce is to reboot the phone...Is it possible to add an exit button in the menu of subsonic Android app to efficently exit?
Thanks for your help.
LGDN
legluondunet
Re: 2 very annoying bugs on subsonic Android client
Postby kleverbear » Sat Nov 12, 2011 4:07 pm
legluondunet wrote:2) subsonic android cient sometimes does not exit correctly, so I have to kill it with a task manager, but it is sometimes not enough, best soluce is to reboot the phone...Is it possible to add an exit button in the menu of subsonic Android app to efficently exit?
YES I need this too!!! It some times starts up on it own if it doesn't exit, to bad right now i cant reach my server anymore. We are using the mytouch 4g (HTC glacier).
Ubuntu 10.04 LTS
Atom @ 1.60GHz, 4 cores 2Gb ram
6 Users
SubSonic 4.6 (build 2585)
2,575 artist
2,053 albums
16,090 songs
288.69GB (~4,484 hours)
kleverbear
Postby bushman4 » Mon Nov 14, 2011 1:00 pm
There is an exit button. Go all the way back to the home screen (or press the home screen button) and then press the menu button on your phone and choose "Exit."
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby kleverbear » Mon Nov 14, 2011 6:55 pm
bushman4 wrote:There is an exit button. Go all the way back to the home screen (or press the home screen button) and then press the menu button on your phone and choose "Exit."
Well what do you know its there! Thanks
Ubuntu 10.04 LTS
6 Users
2,575 artist
2,053 albums
16,090 songs
kleverbear
