Not able to skip thru some h.264 movies
Postby garrich » Sat Nov 12, 2011 10:22 pm
Hi I was wondering if anyone has been having an issue with skipping (ffwd) through H.264 encoded movies? It seems to not to work with the movied i have encoded with Handbrake high profile. when i tried a movie that i encoded with normal profile it worked fine..
[2011-11-12 16:14:45,858] INFO PlaylistInputStream - garrich listening to "LOTR-2002-The_Two_Towers-x284-Rik\LOTR-2002-The_Two_Towers-x284-Rik.m4v"
[2011-11-12 16:14:45,863] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-ss] [0] [-i] [E:\MOVIES\Movies\L-N\LOTR-2002-The_Two_Towers-x284-Rik\LOTR-2002-The_Two_Towers-x284-Rik.m4v] [-async] [1] [-b] [1000k] [-s] [842x352] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
[2011-11-12 16:15:05,308] INFO PlaylistInputStream - garrich listening to "LOTR-2002-The_Two_Towers-x284-Rik\LOTR-2002-The_Two_Towers-x284-Rik.m4v"
[2011-11-12 16:15:05,313] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-ss] [540] [-i] [E:\MOVIES\Movies\L-N\LOTR-2002-The_Two_Towers-x284-Rik\LOTR-2002-The_Two_Towers-x284-Rik.m4v] [-async] [1] [-b] [1000k] [-s] [842x352] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) ffmpeg version N-31653-gfaa3381, Copyright (c) 2000-2011 the FFmpeg developers
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) built on Jul 28 2011 01:57:12 with gcc 4.6.1
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavutil 51. 11. 0 / 51. 11. 0
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavcodec 53. 9. 0 / 53. 9. 0
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavfilter 2. 27. 3 / 2. 27. 3
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (180000/1) -> 90000.00 (180000/2)
[2011-11-12 16:15:05,781] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\MOVIES\Movies\L-N\LOTR-2002-The_Two_Towers-x284-Rik\LOTR-2002-The_Two_Towers-x284-Rik.m4v':
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Metadata:
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) major_brand : mp42
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) minor_version : 0
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) compatible_brands: mp42isomavc1
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) creation_time : 2011-10-21 13:35:06
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) encoder : HandBrake 0.9.5 2011010300
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Duration: 02:59:21.95, start: 0.000000, bitrate: 2234 kb/s
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.0(und): Video: h264 (High), yuv420p, 720x352 [PAR 20944:17921 DAR 42840:17921], 1617 kb/s, PAR 83776:71685 DAR 3808:1593, 23.97 fps, 90k tbr, 90k tbn, 180k tbc
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16, 159 kb/s
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.2(eng): Audio: ac3, 48000 Hz, 6 channels, s16, 448 kb/s
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.3(eng): Subtitle: dvdsub, 3 kb/s
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [buffer @ 019DBF80] w:720 h:352 pixfmt:yuv420p tb:1/1000000 sar:83776/71685 sws_param:
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [scale @ 02DFDF20] w:720 h:352 fmt:yuv420p -> w:842 h:352 fmt:yuv420p flags:0x4
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [libx264 @ 02DFD520] using SAR=20944/17921
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [libx264 @ 02DFD520] MB rate (104940000) > level limit (983040)
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [libx264 @ 02DFD520] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle Cache64
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [libx264 @ 02DFD520] profile High, level 5.1
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [libx264 @ 02DFD520] 264 - core 116 r2037 f8ebd4a - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=3 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc=abr mbtree=0 bitrate=1000 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Output #0, flv, to 'pipe:':
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) encoder : Lavf53.6.0
[2011-11-12 16:15:05,782] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.0(und): Video: libx264, yuv420p, 842x352 [PAR 83776:71685 DAR 200396:71685], q=2-31, 1000 kb/s, 1k tbn, 90k tbc
[2011-11-12 16:15:05,783] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) creation_time : 2011-10-21 13:35:06
[2011-11-12 16:15:05,783] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.1(eng): Audio: libmp3lame, 44100 Hz, 2 channels, s16, 64 kb/s
[2011-11-12 16:15:05,783] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Metadata:
[2011-11-12 16:15:05,783] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream mapping:
[2011-11-12 16:15:05,783] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.0 -> #0.0
[2011-11-12 16:15:05,783] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.1 -> #0.1
[2011-11-12 16:15:05,783] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Press [q] to stop, [?] for help
[2011-11-12 16:15:05,783] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [flv @ 02DFD020] Application provided invalid, non monotonically increasing dts to muxer in stream 0: 23 >= 23
[2011-11-12 16:15:05,783] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) av_interleaved_write_frame(): Invalid argument
garrich
Re: Not able to skip thru some h.264 movies
Postby garrich » Sat Nov 12, 2011 10:27 pm
Sorry forgot to add... im using the lastest beta version.
garrich
Postby kleverbear » Sat Nov 12, 2011 11:30 pm
Since your using handbarake, re-code a couple to mp4 not the default m4v. I have most of my library set to mp4 and does not seem to have an issue.
Ubuntu 10.04 LTS
Atom @ 1.60GHz, 4 cores 2Gb ram
6 Users
SubSonic 4.6 (build 2585)
2,575 artist
2,053 albums
16,090 songs
288.69GB (~4,484 hours)
kleverbear
Postby garrich » Sun Nov 13, 2011 7:37 am
Thanks for the reply.... First i re-encoded a movie with both normal/and high settings, also each with m4v and mp4 containers. All played great with good pictures, but i was not able to skip through any of them. i aslo tried my Avi's (Divx,Xvid) they all worked and skipped. I tried a exisiting mkv file its also worked but when i encoded a dvd to x264 mkv container (handbrake default) it did not skip. So i think its a combination of HB encoding settings and ffmpg transcoding settings..... After about three hours of messing around I changed the ffmpg trancoding setting from -preset superfast to -preset ultrafast... now i can skip on all my files, however the quality suffers at equal bitrates. I have know idea why this works i know nothing about how to adjust the trancoding settings.....so if anyone can help with some ffmpeg setting strings/profiles/presets its would be appreciated. but for now i can live with the quality tradeoff. Thanks.
garrich
