Compiling the android apk
Postby darwusch » Sun Nov 13, 2011 10:22 am
After I compiled the subsonic-main, I would like to compile the android apk, subsonic-android.
The main I compiled with:
mvn clean install
from the root directory of the source folders.
But this is not possible for the android app because there is no pom.xml in that directory.
There is a build.xml file, I guess this should be used, but can anybodey tell me how? With which command?
darwusch
Re: Compiling the android apk
Postby darwusch » Wed Nov 16, 2011 4:52 pm
So many smart people here, I'm sure some of you know the commands to compile the apk.
Anybody?
darwusch
Postby sindre_mehus » Tue Nov 22, 2011 5:59 pm
The android app is compiled with ant. Install ant + Android SDK and do "ant help" for a list of goals.
Cheers,
Postby darwusch » Thu Nov 24, 2011 5:43 pm
Thanks, I get some errors:
C:\Subsonic>cd subsonic-android
C:\Subsonic\subsonic-android>ant
Buildfile: C:\Subsonic\subsonic-android\build.xml
Duplicated project name in import. Project subsonic defined first in C:\Subsonic\subsonic-android\build.xml and again in C:\Progra~2\Android\android-sdk\tools\ant\build.xml
BUILD FAILED
Target "help" does not exist in the project "subsonic".
Total time: 0 seconds
The duplicate name does not seem to be the problem, but the target mentioned in the xml file doesn't seem to exist.
Is this missing?
darwusch
Postby darwusch » Wed Nov 30, 2011 8:43 am
Some extra information.
In the build.xml file (in the root of the subsonic-android directory) the following line seems to cause this error:
<project name="subsonic" default="help">
So I guess it looks for a target named "help", which does not exist. Is this missing or should I change this target?
darwusch
Postby darwusch » Wed Nov 30, 2011 5:21 pm
Ok, after a lot of trying I managed to get a bit further. Now it compiles to an apk file.
Only the last part where the apk should get signed, it fails.
C:\Download\Subsonic\subsonic-android>ant release
Buildfile: C:\Download\Subsonic\subsonic-android\build.xml
-set-mode-check:
-set-release-mode:
-release-obfuscation-check:
-setup:
     [echo] Gathering info for subsonic...
    [setup] Android SDK Tools Revision 15
    [setup] Project Target: Android 2.3.3
    [setup] API level: 10
    [setup]
    [setup] ------------------
    [setup] Resolving library dependencies:
    [setup] No library dependencies.
    [setup]
    [setup]
    [setup] WARNING: Attribute minSdkVersion in AndroidManifest.xml (3) is lower than the project ta
rget API level (10)
-build-setup:
     [echo] Creating output directories if needed...
-pre-build:
-code-gen:
     [echo] ----------
     [echo] Handling aidl files...
     [aidl] No aidl files to compile.
     [echo] ----------
     [echo] Handling RenderScript files...
[renderscript] No renderscript files to compile.
     [echo] ----------
     [echo] Handling Resources...
     [aapt] Found Deleted Target File
     [aapt] Generating resource IDs...
-pre-compile:
-compile:
    [javac] C:\Progra~2\Android\android-sdk\tools\ant\build.xml:600: warning: 'includeantruntime' wa
s not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
    [javac] Compiling 1 source file to C:\Download\Subsonic\subsonic-android\bin\classes
-post-compile:
-obfuscate:
-dex:
      [dex] Found Deleted Target File
      [dex] Converting compiled files and external libraries into C:\Download\Subsonic\subsonic-andr
oid\bin\classes.dex...
-crunch:
   [crunch] Crunching PNG Files in source dir: C:\Download\Subsonic\subsonic-android\res
   [crunch] To destination dir: C:\Download\Subsonic\subsonic-android\bin\res
   [crunch] Crunched 0 PNG files to update cache
-package-resources:
     [aapt] Creating full resource package...
-package:
[apkbuilder] Found Deleted Target File
[apkbuilder] Creating subsonic-release-unsigned.apk for release...
-release-prompt-for-password:
    [input] Please enter keystore password (store:subsonic.keystore):
subsonic
    [input] Please enter password for alias 'subsonic':
subsonic
-release-nosign:
release:
     [echo] Signing final apk...
  [signjar] Signing JAR: C:\Download\Subsonic\subsonic-android\bin\subsonic-release-unsigned.apk to
C:\Download\Subsonic\subsonic-android\bin\subsonic-release-unaligned.apk as subsonic
  [signjar] jarsigner error: java.lang.RuntimeException: keystore load: Keystore was tampered with,
or password was incorrect
BUILD FAILED
C:\Progra~2\Android\android-sdk\tools\ant\build.xml:952: The following error occurred while executin
g this line:
C:\Progra~2\Android\android-sdk\tools\ant\build.xml:965: jarsigner returned: 1
Total time: 29 seconds
How can I fix this?
darwusch
Postby darwusch » Fri Dec 02, 2011 5:56 pm
Ok, I found a work around.
With apk manager I could sign the apk.
Now I run my self-compiled apk on my android phone, very nice.
Thanks for the help.
darwusch
Postby DBendit » Mon Feb 13, 2012 5:34 am
Does anyone know the proper way to work around this? I'm attempting to compile the android APK on linux. I can build it fine with `ant debug` and from Eclipse, but when trying to do `ant release`, no passwords that I provide for the keystores work. Does anyone know the appropriate keystore passwords to allow proper release building of this?
For reference, the output of `ant release`:
Buildfile: /home/dbendit/Development/supersonic/subsonic-android/build.xml
-set-mode-check:
-set-release-mode:
-setup:
    [setup] Android SDK Tools Revision 16
    [setup]
    [setup]
    [setup]
    [setup] WARNING: Attribute minSdkVersion in AndroidManifest.xml (3) is lower than the project target API level (10)
-build-setup:
-pre-build:
-code-gen:
     [echo] ----------
     [aidl] No AIDL files to compile.
     [echo] ----------
[renderscript] No RenderScript files to compile.
     [echo] ----------
     [aapt] No changed resources. R.java and Manifest.java untouched.
-pre-compile:
-compile:
-post-compile:
-obfuscate:
-dex:
      [dex] No new compiled code. No need to convert bytecode to dalvik format.
-crunch:
   [crunch] Crunching PNG Files in source dir: /home/dbendit/Development/supersonic/subsonic-android/res
   [crunch] To destination dir: /home/dbendit/Development/supersonic/subsonic-android/bin/res
-package-resources:
     [aapt] Current build type is different than previous build: forced aapt run.
-package:
[apkbuilder] Current build type is different than previous build: forced apkbuilder run.
subsonic
subsonic
-release-nosign:
release:
  [signjar] Signing JAR: /home/dbendit/Development/supersonic/subsonic-android/bin/subsonic-release-unsigned.apk to /home/dbendit/Development/supersonic/subsonic-android/bin/subsonic-release-unaligned.apk as subsonic
  [signjar] jarsigner error: java.lang.RuntimeException: keystore load: Keystore was tampered with, or password was incorrect
BUILD FAILED
/home/dbendit/Development/android-sdk-linux/tools/ant/build.xml:981: The following error occurred while executing this line:
/home/dbendit/Development/android-sdk-linux/tools/ant/build.xml:994: jarsigner returned: 1
DBendit
