Flac files ripped by different software behave differently??
Postby jhansen317 » Wed Nov 16, 2011 1:13 am
Hello all,
Let me preface this by saying I'm running ubuntu 11.04 and I just installed the latest linux-generic kernel the night before last, so I wonder if thats a factor in this issue.
1st, I spend a lot of time checking out as many cds from the library as possible and ripping them onto my HD. I have come to prefer the .flac format for a variety of reasons, and I use SoundJuicer and Asunder to do the ripping and encoding. Now, I prefer Asunder usually, because I am very very lazy and it uses cddb which recognizes even the most obscure avant-garde 20th and 21st century music. I just found out that I could up the ante with sound juicer and crank up the error correction in gconf, which is to my advantage because a lot of the cds I get from the library are pretty scratched. So, this morning I ripped a few cds with the maximum error correction in Sound juicer, and the others I ripped in Asunder because SJ couldn't give me the track names. Whats strange is that I can't play the SJ-ripped files on my android, and some of them don't even show up in the browser interface. I can play the ones I ripped with asunder just fine. Anyone have any idea whats going on?
FYI: I have no clue which chunk in the log file to display here, but this looks like it might be helpful. I have no idea what the following means, but I saw "WARNING" somewhere so I think this has something to do with the transcoding???
[2011-11-15 19:08:00,244] INFO PlaylistInputStream - admin listening to "Elisabeth Schwarzkopf - Songbook CD 1 - Mozart - Schubert - Mendelssohn - Schumann - Liszt - Brahms - Jensen - Mahler - Strauss/12 - No 8 In der Fremde II.flac"
[2011-11-15 19:08:00,302] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/media/2TB/shared stuff/music/19th Century/Elisabeth Schwarzkopf /Elisabeth Schwarzkopf - Songbook CD 1 - Mozart - Schubert - Mendelssohn - Schumann - Liszt - Brahms - Jensen - Mahler - Strauss/12 - No 8 In der Fremde II.flac] [-v] [0] [-f] [wav] [-]
[2011-11-15 19:08:00,378] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-b] [2147483647] [-S] [--resample] [44.1] [-] [-]
[2011-11-15 19:08:00,452] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) FFmpeg version 0.6.2-4:0.6.2-1ubuntu1.1, Copyright (c) 2000-2010 the Libav developers
[2011-11-15 19:08:00,452] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Sep 16 2011 16:57:46 with gcc 4.5.2
[2011-11-15 19:08:00,452] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
[2011-11-15 19:08:00,453] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   WARNING: library configuration mismatch
[2011-11-15 19:08:00,453] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil   configuration: --extra-version=4:0.6.2-1ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[2011-11-15 19:08:00,453] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec  configuration: --extra-version=4:0.6.2-1ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[2011-11-15 19:08:00,453] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[2011-11-15 19:08:00,453] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[2011-11-15 19:08:00,453] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[2011-11-15 19:08:00,454] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale  configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[2011-11-15 19:08:00,454] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
[2011-11-15 19:08:00,454] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil     50.15. 1 / 50.15. 1
[2011-11-15 19:08:00,454] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec    52.72. 2 / 52.72. 2
[2011-11-15 19:08:00,454] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat   52.64. 2 / 52.64. 2
[2011-11-15 19:08:00,455] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice   52. 2. 0 / 52. 2. 0
[2011-11-15 19:08:00,455] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter    1.19. 0 /  1.19. 0
[2011-11-15 19:08:00,455] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale     0.11. 0 /  0.11. 0
[2011-11-15 19:08:00,455] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc   51. 2. 0 / 51. 2. 0
[2011-11-15 19:08:00,507] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, flac, from '/media/2TB/shared stuff/music/19th Century/Elisabeth Schwarzkopf /Elisabeth Schwarzkopf - Songbook CD 1 - Mozart - Schubert - Mendelssohn - Schumann - Liszt - Brahms - Jensen - Mahler - Strauss/12 - No 8 In der Fremde II.flac':
[2011-11-15 19:08:00,507] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2011-11-15 19:08:00,507] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TRACKNUMBER     : 12
[2011-11-15 19:08:00,507] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     ARTIST          : Elisabeth Schwarzkopf - Soprano; Gerald Moore, Geoffrey Parsons, Nicolas Medtner, Cyril Szalkiewicz - Klavier
[2011-11-15 19:08:00,507] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     ALBUM           : Elisabeth Schwarzkopf - Songbook CD 1
[2011-11-15 19:08:00,507] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TITLE           : No 8 In der Fremde II
[2011-11-15 19:08:00,507] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     DATE            : 1995
[2011-11-15 19:08:00,508] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:01:15.50, bitrate: 482 kb/s
[2011-11-15 19:08:00,508] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: flac, 44100 Hz, 2 channels, s16
[2011-11-15 19:08:00,509] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, wav, to 'pipe:':
[2011-11-15 19:08:00,509] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2011-11-15 19:08:00,509] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     encoder         : Lavf52.64.2
[2011-11-15 19:08:00,510] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[2011-11-15 19:08:00,510] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2011-11-15 19:08:00,510] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2011-11-15 19:08:00,510] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop encoding
[2011-11-15 19:08:01,699] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   13007kB time=75.51 bitrate=1411.2kbits/s
[2011-11-15 19:08:01,699] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) video:0kB audio:13007kB global headers:0kB muxing overhead 0.000330%
jhansen317
