Subsonic 4.6 Beta 2 issues
Postby monkey » Fri Nov 18, 2011 7:04 pm
Just upgraded from beta 1 to beta 2 and subsonic will not start
Error in /var/subsonic/subsonic_sh.log is
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x0118da50, pid=17176, tid=3077938032
# JRE version: 6.0_23-b23
# Java VM: OpenJDK Client VM (20.0-b11 mixed mode, sharing linux-x86 )
# Derivative: IcedTea6 1.11pre
# Distribution: Ubuntu 11.10, package 6b23~pre11-0ubuntu1.11.10
# Problematic frame:
# V  [libjvm.so+0x201a50]  AbstractInterpreter::method_kind(methodHandle)+0x70
and in /usr/share/subsonic/hs_err_pid17176.log
Java Threads: ( => current thread )
Other Threads:
=>0x08dd4400 (exited) JavaThread "Unknown thread" [_thread_in_vm, id=17177, stack(0xb7709000,0xb775a000)]
VM state:not at safepoint (not fully initialized)
VM Mutex/Monitor currently owned by a thread: None
VM Arguments:
jvm_args: -Xmx100m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=4040 -Dsubsonic.httpsPort=0 -Dsubsonic.contextPath=/$
java_command: subsonic-booter-jar-with-dependencies.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/sbin:/usr/sbin:/bin:/usr/bin
LD_LIBRARY_PATH=/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client:/usr/lib/jvm/java-6-openjdk/jre/lib/i386:/usr/lib/jvm/java-6-openjdk/jre/../l$
I can post the full error logs if needed
JRE is installed, latest edition, Ubuntu Server 11.10, have reverted back to 4.5 without issues
Any clues or suggestions welcome!
Iain
monkey
Re: Subsonic 4.6 Beta 2 issues
Postby monkey » Sat Nov 19, 2011 5:53 pm
Is beta 1 still available for download?
monkey
Postby BKKKPewsey » Sat Nov 19, 2011 6:01 pm
Yes
Postby monkey » Sat Nov 19, 2011 6:07 pm
Dah! Got it from sourceforge! Ta!
monkey
Postby monkey » Sat Nov 19, 2011 6:22 pm
Grrrrr!
Tried removing and installing beta 1, no joy.
Tried removing and rolling back to 4.5 now that won't start either.
Tried removing JRE and reinstalling, STILL no joy!
Not impressed that a public beta could cause so much damage!
monkey
Postby BKKKPewsey » Sat Nov 19, 2011 6:44 pm
Looking at the posts here there does seem to be quite a few recent problems with Ubuntu installs.
I wonder if a recent update (JRE?) may be causing some compatibility problem. :?
Postby wowo » Sat Nov 19, 2011 7:04 pm
BKKKPewsey wrote:Looking at the posts here there does seem to be quite a few recent problems with Ubuntu installs.
I have for testing Subsonic also on my Ubuntu pc installed and I have no problems.
However I do not use openjdk but the official java : sun-java6-jre
So maybe your thoughts about a recent update of openjdk could be the cause.
Subsonic 4.7 (build 3105) running on QNAP TS-239 Pro II (Intel Atom 1.8GHz Single-core ; 1GB RAM)
wowo
Postby monkey » Sat Nov 19, 2011 7:21 pm
After switching java to the sun version, 4.6 beta 1 is back up and running, however when I update to beta 2, I get a 404 error till I manually specified 4040 as the port in /etc/default/subsonic which I'm certain I didn't have to do before, but hey ho, mystery solved, openjava screwed something up!
Thanks for your help guys!
monkey
Users browsing this forum: Google [Bot] and 21 guests
