Take out Jetty? Any other dependencies besides web browsers?
Postby dman777 » Sun Nov 20, 2011 1:49 pm
I do not use the web browser portion of subsonic. I only use the android client app to connect to my subsonic server. I would like to disable jetty to keep any exploits from happening. If I disable jetty by renaming the directory, are there any other dependencies on it besides the web browser portion?
dman777
Re: Take out Jetty? Any other dependencies besides web brows
Postby Drefsab » Sun Nov 20, 2011 4:57 pm
if you do that I suspect you wont be able to connect using the android app, as I think its required as its jetty thats serving all the data to your client out,
Drefsab
Users browsing this forum: Google [Bot] and 7 guests
