but some abuse the privilege!
but some abuse the privilege!kleverbear wrote:FYI your log link does not seem to pull up a page
but some abuse the privilege!kleverbear wrote:alvar.berglind have you by chance restared your server? It seems that after the java update SS needs to rebuild its DB from scratch, been testing this since others have had a very similar problem. So far an easy way is to remove a folder and let SS rebuild then re-add the folder and let it rebuild again. I've tested this theory so far twice with success. Give it a shot and hope it works.
kleverbear wrote:In SS Settings >Media folders there is a enable check box next to each share, i'm surmising you have videos on another directory other than music. Hope this make snece.
kleverbear wrote: It seems that after the java update SS needs to rebuild its DB from scratch
but some abuse the privilege!Users browsing this forum: No registered users and 91 guests
