Layman needs aid for subsonic on iphone 4
Postby robmorast » Thu Nov 24, 2011 6:19 pm
Hey,
Subsonic was working very well on my iphone and suddenly stopped. I can get it to work while the phone is using a wifi setting, but it won't run on 3G settings. any help is appreciated. thanks, in advance.
Problem Description: Subsonic was working very well on my iphone 4 and suddenly stopped. I can get it to work while the phone is using a wifi setting, but it won't run on 3G settings. on the localhost page, the network settings say it successfully forwards to port 80, and my subsonic web page is registered, but it can't connect and gets the "connect timeout exception".
Troubleshooting Steps: the basics; restarting the router, switching port from 80 to 4040 and back
Playback Application and version:
Subsonic Version: 4.5 (build 2385) – August 11, 2011, i believe
Server Version: jetty-6.1.x, java 1.6.0_20, Windows XP (29.5 MB / 68.6 MB)
Hardware Platform: Windows xp
Java Memory Limit: 100
Problem Filename:
Output from ffmpeg -i: honestly, i don't know much about this stuff.
Last ten log file lines:
[11/24/11 11:57:53 AM CST] INFO DaoHelper Checking database schema.
[11/24/11 11:57:53 AM CST] INFO DaoHelper Done checking database schema.
[11/24/11 11:57:54 AM CST] INFO SearchService Automatic index creation scheduled to run every 1 day(s), starting at Fri Nov 25 03:00:00 CST 2011
[11/24/11 11:57:55 AM CST] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Thu Nov 24 12:02:55 CST 2011
[11/24/11 11:58:03 AM CST] INFO NetworkService Successfully forwarding port 80.
[11/24/11 11:58:36 AM CST] INFO VersionService Resolved local Subsonic version to: 4.5
[11/24/11 11:58:36 AM CST] INFO VersionService Resolved latest Subsonic final version to: 4.5
[11/24/11 11:58:36 AM CST] INFO VersionService Resolved latest Subsonic beta version to: 4.6.beta1
[11/24/11 11:59:00 AM CST] WARN JaudiotaggerParser Error when parsing tags in C:\Documents and Settings\HP_Administrator\My Documents\My Music\iTunes\iTunes Music\05+Two+Out+Of+Three+Ain 27t+Bad.mp3
[11/24/11 11:59:03 AM CST] WARN JaudiotaggerParser Error when parsing tags in C:\Documents and Settings\HP_Administrator\My Documents\My Music\iTunes\iTunes Music\esquivel-MiniSkirt.mp3
[11/24/11 11:59:04 AM CST] INFO NetworkService Successfully forwarding port 80.
[11/24/11 12:02:32 PM CST] INFO NetworkService Successfully forwarding port 80.
[11/24/11 12:02:55 PM CST] INFO PodcastService Starting scheduled Podcast refresh.
[11/24/11 12:02:55 PM CST] INFO PodcastService Completed scheduled Podcast refresh.
robmorast
Re: Layman needs aid for subsonic on iphone 4
Postby BKKKPewsey » Thu Nov 24, 2011 6:51 pm
I would suggest not using port 80 as ISP's have a habit of blocking that port if they think there is a server online.
Check with http://canyouseeme.org and check that the port you choose is open.
If they cannot see you nor will anything else. If they can't you will have to open the port manually in the router.
Postby robmorast » Thu Nov 24, 2011 7:05 pm
thanks for the help. i shifted the port number and it worked for a bit - but very, very slow. now it's timing out, again.
robmorast
Postby BKKKPewsey » Thu Nov 24, 2011 7:25 pm
Check using another pc outside your lan - You need to determine whether its your internet connection or the 3G network.
You may want to increase your memory limit (java) try 256MB which should eliminate that from the equation.
Postby robmorast » Thu Nov 24, 2011 8:48 pm
it's not working on outside PCs either.
robmorast
Postby BKKKPewsey » Thu Nov 24, 2011 10:05 pm
Did the canyouseeme test pass?
If it did I would do an internet speed test - your ISP may be having problems or your router is having a bad day :?
