Subsonic 4.6.beta2 issue..
Postby daniell » Sun Nov 27, 2011 8:46 am
Firefox v/8 freeze and hang when i play movies and flac files..
Seems like Adobe Flash player is playing a major part in this problem. Chrome working just fine..
Running Windows 7 x64, Firefox 8 and Adobe Flash player 11.
Any solution for this problem ??
Supermicro Intel(R) Core(TM) i7-3555LE CPU @ 2.50GHz, 4 cores 8gb ram
CentOS Linux 6.6 Server, jetty-6.1.x, java 1.7.0_71, Linux (143,2 MB / 437,5 MB) Subsonic 5.1
Supermicro Intel® Atom™ D510 4gb ram
Sophos Security Gateway UTM /v9
daniell
Re: Subsonic 4.6.beta2 issue..
Postby BKKKPewsey » Sun Nov 27, 2011 1:41 pm
I would suggest this is more of a firefox problem then subsonic :?
Solution: Don't use FF :D or make sure your add-ins are up to date.
FF8 is playing vids np here but I have got latest Adobe flash update.
Postby schitonk » Tue Nov 29, 2011 8:43 pm
I am running SS 4.5 with same version FF and latest Flash (11.1.102.55) on both Win 7 32 and 64 bit and cannot play any video. IE 9 works.
schitonk
Postby BKKKPewsey » Tue Nov 29, 2011 9:22 pm
Odd its the same version that I have (did have an issue until I upgraded flash) :?
Perhaps its a plugin compatibility problem. Try disabling any plugins and see if that makes a difference.
Postby schitonk » Tue Nov 29, 2011 10:54 pm
Disabling add-ons make no difference:
video starts to load, FF becomes unresponsive and Flash crashes after about 20 seconds. I'm not seeing any errors in firebug either. I will try downgrading Flash tonight to see if this persists.
schitonk
Postby nelgin » Mon Dec 05, 2011 7:13 pm
Try downgrading the browser. I'm having all sorts of problems with Firefox on my work laptop after it's been running a while. It'll gradually grind to a halt.
nelgin
