Subsonic's redirect not working
Postby Toxeia » Sun Nov 27, 2011 6:40 pm
Running server 4.5 (build 2385), 3.0.1 on my Kindle Fire. Using port 8080.
I can connect to my Ss server by using my local IP, my WAN ip, and another dynamic DNS provider (toxeia.linkpc.net). With all of these I provide the port number at the end of the address. However, toxeia.subsonic.org doesn't work, providing the port or no. I've tried it with my firewall on and off and still no luck with the subsonic address. The other 3 methods work fine regardless of the firewall though. Tad confused on this.
I did originally try setting this up on port 80, and that's when I registered toxeia.subsonic.org, could this be the cause of the problem? Do I need to make it update the registration?
Any help is much appreciated, thank you.
Toxeia
Toxeia
Re: Subsonic's redirect not working
Postby BKKKPewsey » Sun Nov 27, 2011 9:15 pm
If you go to settings/network and hit save it will update your SS org address
Users browsing this forum: Google [Bot] and 22 guests
