Unable to connect via LAN with Android
Postby gck303 » Tue Nov 29, 2011 9:59 am
I have configured my subsonic installation and router and I am able to stream when my Android (Nexus One) is connected to the phone network. So, I know my subsonic installation etc works. I use the xxx.subsonic.org address to do this. ( 4.5 (build 2384) – August 10, 2011; jetty-6.1.x, java 1.6.0_20, Linux (30.6 MB / 63.2 MB))
I cannot get my Android phone to connect via the LAN when it uses WiFi. The two servers are on the same network domain subnet etc.
If I open up a browser on my phone I can log in, but the SubSonic application does not work. It gives me a network 1...4 error.
What am I doing wrong?
Thanks, George
gck303
Re: Unable to connect via LAN with Android
Postby gck303 » Thu Dec 01, 2011 9:41 am
I am still unable to get this to work after much trying and experimentation.
Is it likely to be a subsonic or network problem?
Please help as this a critical function to make subsonic a useful product for me.
George
gck303
Postby Leonard26 » Thu Dec 01, 2011 7:17 pm
Is it only your home wifi where this doesn't work? Does it work from a public wifi or at a friend/family's house?
I had a similar problem with connection from my local wifi on my EVO 4g. I'm not positive, but I think it was a local DNS issue.
All I did was add a second server connection in the app pointing to the IP Address instead of the DNS/server name, ie http://192.168.1.7/subsonic/
Hope that helps...
Leonard26
