connection problem
connection problem
Postby Rhook » Tue Nov 29, 2011 6:48 pm
Still trying to get things going here. Successfully forwarding to port 80, and my http:subsonic.org is registered except it says it cannot connect. I am using an airport extreme through my PC. I checked out portforward.com but it's info was out of date. I am also getting a connection failure on my iPhone. I am running the Windows firewall program. It didn't help to turn it off. Any ideas?
Thanks for your time,
Rusty
Rhook
Re: connection problem
Postby BKKKPewsey » Tue Nov 29, 2011 6:57 pm
Check with http://canyouseeme.org and see if the port is open.
Postby BKKKPewsey » Tue Nov 29, 2011 11:20 pm
Its usually a bad idea to use port 80 because that is the standard http port and all the windows services will try to use it.
Put SS on its own dedicated port (say 8080) forward that port and test with canyouseeme.
Users browsing this forum: Google [Bot] and 32 guests
