Search function not working
Postby johnny.croy » Fri Dec 02, 2011 3:22 am
Having a problem with search.
Setup is as follows:
1. Have a MacPro running latest Lion in a dual boot config. Windows partition contains all of my music (use Subsonic on both sides) in a artist/album/track format. Windows drive is formatted with NFTS (is running latest Windows 7).
2. Using Tuxera NFTS to mount windows drive in Lion with read/write privileges. Have confirmed that I have r/w to this drive.
3. In my subsonic setup (running latest 4.5 version, paid), the media folder is pointed to this NTFS mounted directory and I get all of my music loaded with no problems. Music is listenable and I see the individual folders on the left hand view. Clicking on an artist brings up the respective albums and I can choose from there. However, when I try and search for an artist/album/track/etc from the search box, I get no results.
4. Using iSUB on iPhone and can login to the server, but again the folder view shows that access to the folder is restricted when I try and search or use the folder shortcut. However, if I use the random album selection mode, I can get albums and they play without error.
I assume that it has something to do with the NTFS mount and access. Don't know where to start. Anyone here have a similar setup?
Best,
J
johnny.croy
Re: Search function not working
Postby BKKKPewsey » Fri Dec 02, 2011 4:01 am
Update your search index and then check the SS log and see if there are any errors.
Postby johnny.croy » Fri Dec 02, 2011 12:00 pm
B,
Yup, refreshed several times. No apparent error, see output below.
[12/2/11 6:49:55 AM EST] INFO SearchService Starting to create search index.
[12/2/11 6:50:06 AM EST] INFO SearchService Created search index with 1000 entries.
[12/2/11 6:50:07 AM EST] INFO SearchService Created search index with 2000 entries.
[12/2/11 6:50:14 AM EST] INFO SearchService Created search index with 3000 entries.
[12/2/11 6:50:24 AM EST] INFO SearchService Created search index with 4000 entries.
[12/2/11 6:50:33 AM EST] INFO SearchService Created search index with 5000 entries.
[12/2/11 6:50:37 AM EST] INFO SearchService Created search index with 6000 entries.
[12/2/11 6:50:39 AM EST] INFO SearchService Created search index with 7000 entries.
[12/2/11 6:50:50 AM EST] INFO SearchService Created search index with 8000 entries.
[12/2/11 6:50:58 AM EST] INFO SearchService Created search index with 9000 entries.
[12/2/11 6:50:59 AM EST] INFO SearchService Created search index with 10000 entries.
[12/2/11 6:51:01 AM EST] INFO SearchService Created search index with 11000 entries.
[12/2/11 6:51:02 AM EST] INFO SearchService Created search index with 12000 entries.
[12/2/11 6:51:05 AM EST] INFO SearchService Created search index with 13000 entries.
[12/2/11 6:51:14 AM EST] INFO SearchService Created search index with 14000 entries.
[12/2/11 6:51:25 AM EST] INFO SearchService Created search index with 15000 entries.
[12/2/11 6:51:32 AM EST] INFO SearchService Created search index with 16000 entries.
[12/2/11 6:52:11 AM EST] INFO SearchService Created search index with 17000 entries.
[12/2/11 6:52:59 AM EST] INFO SearchService Created search index with 18000 entries.
[12/2/11 6:53:52 AM EST] INFO SearchService Created search index with 19000 entries.
[12/2/11 6:54:30 AM EST] INFO SearchService Created search index with 20000 entries.
[12/2/11 6:55:18 AM EST] INFO SearchService Created search index with 21000 entries.
[12/2/11 6:56:11 AM EST] INFO SearchService Created search index with 22000 entries.
[12/2/11 6:57:12 AM EST] INFO SearchService Created search index with 23000 entries.
[12/2/11 6:58:12 AM EST] INFO SearchService Created search index with 24000 entries.
[12/2/11 6:59:03 AM EST] INFO SearchService Created search index with 25000 entries.
I am getting a network error and I don't think that I have seen this one before
[12/2/11 6:12:13 AM EST] WARN NetworkService Failed to find UPnP router using SBBI library.
[12/2/11 6:12:16 AM EST] WARN NetworkService No UPnP router found.
However, I don't think that it the root of my search issues.
Best,
J
johnny.croy
Postby BKKKPewsey » Fri Dec 02, 2011 12:26 pm
If you have manually forwarded the ports in your router you can ignore those network warnings
You should have had at the end of the search index listing something like :-
[02/12/11 05:23:12 GMT]   INFO   SearchService   Updating Lucene search index.
[02/12/11 05:23:30 GMT]   INFO   SearchService   Created search index with 76230 entries.
Did you?
