Unable to use network shares in Windows? 4.6
Postby eblade » Wed Dec 07, 2011 10:22 am
I'm attempting to get Subsonic to use a network share. If I specify it as a regular UNC path, ie \\SERVER\Music, or if I mount it as a regular drive, ie M:\, all I get is "No media folders found. Please change the settings."
Using subsonic 4.6.
eblade
Re: Unable to use network shares in Windows? 2.6
Postby BKKKPewsey » Wed Dec 07, 2011 11:46 am
eblade wrote:Using subsonic 2.6.
You may want to think about updating :?
Postby bushman4 » Wed Dec 07, 2011 2:25 pm
Have you changed the service to run using a username and password that has access to the UNC path? The LocalSystem account (the default) does not.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby eblade » Fri Dec 09, 2011 9:25 am
oops, i meant 4.6. my bad. i've been ill lately, my head isn't always agreeing with where it thinks it is. :D
Umm.. I'll try that, though I'm pretty sure that that shouldn't make a difference for the mounted drive .. *goes off to have a look*
* edit: nope, does not work. tried NetworkService first, restarted, no go, then tried as the user that I've mounted the drive as, restarted, and no go.
eblade
Postby Aethies » Fri Dec 09, 2011 2:14 pm
eblade wrote:oops, i meant 4.6. my bad. i've been ill lately, my head isn't always agreeing with where it thinks it is. :D
Can you take a screenie of the media folders screen or at least put in here exactly how you have them?
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Re: Unable to use network shares in Windows? 4.6
Postby GJ51 » Fri Dec 09, 2011 7:30 pm
Just follow the instructions for setting the logon rights to the Subsonic service as explained in the tutorial posted in the link below.
http://monroeworld.com/android/subsonic/
Postby eblade » Sat Dec 10, 2011 1:27 am
Yeah, that is what I did, and still no love there. Just "No Music Folders"
eblade
Postby BKKKPewsey » Sat Dec 10, 2011 1:33 am
Aethies wrote:Can you take a screenie of the media folders screen or at least put in here exactly how you have them?
Postby smoothcriminal » Fri Feb 15, 2013 8:10 am
I found the solution to this problem. You need to change the share permissions to allow "Authenticated Users" if the share is backed by windows. Once I did this, everything worked.
smoothcriminal
Postby GJ51 » Fri Feb 15, 2013 4:16 pm
You also need to set up identical accounts on both machines with the same username and password.
eg:
Storage Server: admin - password
Subsonic Server: admin - password
Subsonic Service account: admin - password
All 3 need to be identical and admin - password has to have valid permissions to \\Music share on the storage UNC.
Users browsing this forum: Google [Bot] and 22 guests
