[android] remote control not works
Postby jaja » Thu Dec 08, 2011 9:01 pm
Hi !
I update subsonic tio 4.6 today.
When I want test remote control nothing hapens.
subsonic.log :
[08/12/11 21:54:46 CET]    DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/media/sda1/musique/Collection/Albums/Gamble 202/1995 - Jazzy/01.Jazzy.mp3] [-v] [0] [-f] [au] [-]
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) built on Aug 9 2011 14:18:27 with gcc 4.5.2
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavutil 51. 11. 1 / 51. 11. 1
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavcodec 53. 9. 1 / 53. 9. 1
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavfilter 2. 28. 1 / 2. 28. 1
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [mp3 @ 0x964fb20] max_analyze_duration 5000000 reached at 5015510
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Input #0, mp3, from '/media/sda1/musique/Collection/Albums/Gamble 202/1995 - Jazzy/01.Jazzy.mp3':
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Metadata:
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) title : Jazzy
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) genre : Techno, Acid
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) TLEN : 371122
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) TBPM : 70
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) artist : Gamble 202
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) album : Jazzy
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) date : 1995
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) track : 01
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) TCMP : 0
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) FMPS_Rating : 1
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) FMPS_Rating_Amarok_Score: 0.75
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) FMPS_Playcount : 2
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Duration: 00:06:11.09, start: 0.000000, bitrate: 192 kb/s
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: mp3, 44100 Hz, stereo, s16, 192 kb/s
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Output #0, au, to 'pipe:':
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) encoder : Lavf53.6.0
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: pcm_s16be, 44100 Hz, stereo, s16, 1411 kb/s
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream mapping:
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[08/12/11 21:54:46 CET]    ERROR   JukeboxService   Error in jukebox: javax.sound.sampled.LineUnavailableException
[08/12/11 21:54:46 CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) av_interleaved_write_frame(): Operation not permitted
under kubuntu 11.10 (32 bits), KDE SC 4.7.3.
thanks ;)
regards
jaja
jaja
Re: [android] remote control not works
Postby tomm1111 » Fri Dec 09, 2011 11:54 pm
I am in the same spot. We have the OS in common Ubuntu 11.04 32bit. No real cluses on where to start troubleshooting. I can see the player advancing when I queue a song, but no sound. If I switch the player the the Web Playser Setting is plays fine. So sad as this is a great feature and it works fine on a different machine.
tomm1111
Postby BKKKPewsey » Sat Dec 10, 2011 1:44 am
Using the web interface does jukebox work ok?
Postby jaja » Sat Dec 10, 2011 11:46 pm
how verify that ?
when I activate remote control and play song with my android client, nothing happens web interface on my computer.
regards
jaja
jaja
Users browsing this forum: Google [Bot] and 32 guests
