Subsonic does not find my playlists
Postby atomicdogg » Fri Dec 09, 2011 6:20 pm
I have multiple playlist (all .m3u) in the following folder configuration
X:\shares\Music\Playlists
When I manually navigate to the folder though windows explorer all files are present but when I browse though Subsonic or use the search they do not show up. I have updated my search index multiple times and the playlist folder is correct under general settings. The crazy part is they show up though the Android app in but not the web browser. (IE 9 or Firefox 8.0)
Running the following:
Windows Home Server 2003
Version 4.6 (build 2583) – December 6, 2011
Server jetty-6.1.x, java 1.6.0_29, Windows 2003 (72.6 MB / 96.7 MB)
Firefox 8.0
Any suggestions on how to get these file to appear in Subsonic would be greatly appreciated.
atomicdogg
Re: Subsonic does not find my playlists
Postby BKKKPewsey » Fri Dec 09, 2011 9:54 pm
By not show up I assume that when you select load playlist there is nothing there?
Save a playlist from SS and see where that goes and if it appears.
Postby atomicdogg » Sat Dec 10, 2011 2:17 pm
Thank you for the response.
When I select load playlist they show up, load and play.
It's when I manually navigate to the Playlist folder in Subsonic they don't show up. When I say manually navigate I mean using the list/folders on the far left hand side of the screen in the web browser.... Collection, Waves, Playlists.
My folder structure is as follows
X:\Music\Collection - Where I keep all my mp3's
X:\Music\Waves - Where I keep edited and unedited waves files
X:\Music\Playlists - Where I store all my playlists
It's not that big of a deal, just a minor annoyance that I can't navigate to a specific playlist without using the player actions.
Do I have something wrong with folder structure?
Thanks for the help.
atomicdogg
Postby BKKKPewsey » Sat Dec 10, 2011 5:36 pm
No - They will not show as they are not music files.
If you add m3u as a music file type they will show but you will not be able to play it.
