Need some help with security issues
Postby tenzip » Mon Dec 12, 2011 3:14 am
Hi all, I'm hoping you can give me some guidance on how to adjust, modify, or tweak Subsonic to be more secure.
Here's the scenario. My Subsonic server has recently been moved to work, both to get it off my home PC, and to let some folks at work use it, as radio reception inside metal buildings (read: Faraday cages) is extremely limited.
The problem comes with an external security scan that happened to fall on the same evening that I got the Subsonic server running. It identified several "failing" vulnerabilities that are related to Subsonic. Basically, the scan probes every port available on our public IP, and reports back when something answers. If it does answer, it also checks to see if any "weaknesses" are exposed.
Here is one of the results from the latest scan:
Web Server HTTP Header Internal IP Disclosure Web Services :: Nessus ID 110759 Port TCP:8442 Risk 3
This may expose internal IP addresses that are usually hidden or masked behind a Network Address Translation (NAT) Firewall or proxy server.
Information from Target: When processing the following request : GET / HTTP/1.0
this web server leaks the following private IP address :
10.0.0.184
as found in the following collection of HTTP headers :
HTTP/1.1 302 Found\r
Content-Length: 0\r
Server: Jetty(6.1.x)\r
\r
The same issue occurs with port :8443.
8442 is my Subsonic installation's "standard" http port, 8443 is https, I used these because 80 and 443 were already being used by other servers at work.
I personally couldn't care less that it's exposing an internal IP. Since that IP range is not routable, I don't see how it could be used to compromise the network, but the folks doing the scan have the last word. It's a failure to them, so it needs to be corrected. (To me, if they are able to use non-routable, private IPs in an attack, they're already inside, so it makes no difference.)
The other "failures" involve cipher strength, on :8443, the issue is it will accept ciphers <112 bit strength, again, this is considered a failure.
So, my question, at last, is, are the above "failures" correctable, and how would one go about correcting them?
Subsonic environmental info:
Version 4.6 (build 2583) – December 6, 2011
Server jetty-6.1.x, java 1.6.0_29, Windows 7 (53.9 MB / 175.4 MB)
Running on an old storage server now running Win7 Ultimate x64, Xeon, 4TB storage, 1GB memory.
edited to correct a mis-statement about which errors occurred on which port.
tenzip
Re: Need some help with security issues
Postby sindre_mehus » Fri Dec 16, 2011 9:46 pm
I don't think there's a way to suppress the "Location" http header in Jetty (which is the container used by Subsonic).
I'm a bit surprised to hear that the certificate bundled with Subsonic uses a cipher length of <112 bits, I thought it was 1024 bits. I can look into that. Either way, you can hook your own certificate into Subsonic by setting the following Java system properties:
subsonic.ssl.keystore - Path to an alternate SSL keystore.
subsonic.ssl.password - Password of the alternate SSL keystore.
On Windows, these can be set in c:/program files/subsonic-service.exe.vmoptions.
Postby BKKKPewsey » Fri Dec 16, 2011 10:42 pm
FYI Subsonic certificate report and comparison with WHS and google
Subsonic
WHS
Google
Postby mikes » Fri Dec 16, 2011 10:58 pm
sindre_mehus wrote:I'm a bit surprised to hear that the certificate bundled with Subsonic uses a cipher length of <112 bits, I thought it was 1024 bits.
1024 is the key length, from the certificate, which is used for authentication. Encryption is separate. It looks like jetty supports weak encryption as the default configuration, and the ciphers are old (SSL_DHE_RSA_WITH_DES_CBC_SHA and SSL_DHE_DSS_WITH_DES_CBC_SHA are 56 bit). You may be able to pick others available in the current version of the JVM, and use 1 or more of those (like TLS_DHE_RSA_WITH_AES_256_CBC_SHA) in place of the defaults. Not that up on Java, or I'd try to help more. Also see here.
mikes
Postby tenzip » Sat Dec 17, 2011 4:10 am
Thank you for the replies, Sindre, BK, mikes.
So, perhaps there is hope for the cipher "failures", but no known way to stop Jetty from reporting the IP address? Am I correct in that?
I may need to find another excuse to get a couple more static IPs from our ISP, so I can put the box Subsonic is on in a DMZ, firewall it from our LAN, and use one of the other public IPs for it.
Again, if I can provide any additional info to help, please let me know.
tenzip
