Subsonic on Lubuntu
Subsonic on Lubuntu
Postby ftdube » Thu Dec 15, 2011 5:37 am
Hi!
I just installed subsonic on a Lubuntu based server. Everything seems to work fine except for the jukebox mode. Is anyone aware if Jukebox works properly on Lubuntu and if so, could someone walk me through the steps in order to make this work properly?
Thanks everyone!
ftdube
Re: Subsonic on Lubuntu
Postby ftdube » Thu Dec 15, 2011 11:12 pm
Just giving a little bit more details about this. I'm using the default user (root) so, if I 'm not mistaken, I don't need to make it part of the audio group. Also, I only have one audio device so that shouldn't be a problem. Thanks in advance!
ftdube
Postby ftdube » Fri Dec 16, 2011 3:39 am
Another update. I checked the logs. I have a message saying Home directory /home/ftdube not ours. Does it ring any bell to anyone?
ftdube
Postby ftdube » Fri Dec 16, 2011 3:55 am
Ah, Found an exception in the other log file.
[2011-12-15 22:52:07,128] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[2011-12-15 22:52:07,151] ERROR JukeboxService - Error in jukebox: javax.sound.sampled.LineUnavailableException
   at org.classpath.icedtea.pulseaudio.PulseAudioMixer.openImpl(PulseAudioMixer.java:714)
   at org.classpath.icedtea.pulseaudio.PulseAudioMixer.openLocal(PulseAudioMixer.java:588)
   at org.classpath.icedtea.pulseaudio.PulseAudioMixer.openLocal(PulseAudioMixer.java:584)
   at org.classpath.icedtea.pulseaudio.PulseAudioMixer.open(PulseAudioMixer.java:579)
   at org.classpath.icedtea.pulseaudio.PulseAudioDataLine.open(PulseAudioDataLine.java:94)
   at org.classpath.icedtea.pulseaudio.PulseAudioSourceDataLine.open(PulseAudioSourceDataLine.java:75)
   at org.classpath.icedtea.pulseaudio.PulseAudioSourceDataLine.open(PulseAudioSourceDataLine.java:90)
   at net.sourceforge.subsonic.service.jukebox.AudioPlayer.<init>(AudioPlayer.java:61)
   at net.sourceforge.subsonic.service.JukeboxService.play(JukeboxService.java:106)
   at net.sourceforge.subsonic.service.JukeboxService.updateJukebox(JukeboxService.java:75)
   at net.sourceforge.subsonic.ajax.PlaylistService.convert(PlaylistService.java:307)
   at net.sourceforge.subsonic.ajax.PlaylistService.doSkip(PlaylistService.java:105)
   at net.sourceforge.subsonic.controller.RESTController.jukeboxControl(RESTController.java:403)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:616)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
   at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
   at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:122)
[2011-12-15 22:52:07,167] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=      90kB time=00:00:00.52 bitrate=1411.6kbits/s
ftdube
Postby ftdube » Fri Dec 16, 2011 5:00 am
Installed sun JDK, uninstalled openJDK, set sun JDK as default, rebooted, solved!
Thanks to anyone who tried to help!
ftdube
