Transcoder just not working.
Postby willm » Thu Dec 15, 2011 1:51 pm
HI
I cannot transcode m4a or flac using the provided transcoder. Keep getting this:
FLAC:
2011-12-15 17:46:19,961] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/var/music/A Tribe Called Quest/Midnight Marauders/01 Phoney Rappers.flac] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[2011-12-15 17:46:19,985] WARN TranscodingService - Failed to transcode /var/music/A Tribe Called Quest/Midnight Marauders/01 Phoney Rappers.flac. Using original.
java.io.IOException: Cannot run program "/var/subsonic/transcode/ffmpeg": java.io.IOException: error=12, Cannot allocate memory
M4A:
[2011-12-15 17:54:05,862] INFO PlaylistInputStream - admin listening to "Midnight Marauders/01 Phoney Rappers.m4a"
[2011-12-15 17:54:05,869] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/var/music/A Tribe Called Quest/Midnight Marauders/01 Phoney Rappers.m4a] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[2011-12-15 17:54:05,906] WARN TranscodingService - Failed to transcode /var/music/A Tribe Called Quest/Midnight Marauders/01 Phoney Rappers.m4a. Using original.
Please somebody help as its driving me bonkers. I just had the CentOS server rebuilt to address an issue with glibc not being a high enough version.
willm
Re: Transcoder just not working.
Postby Aethies » Thu Dec 15, 2011 2:22 pm
Did you try increasing the allocated memory for Java? There are numerous threads on how to increase memory for whatever platform you are on. The defaulted allotment of 100M is not nearly enough, but like some have posted, do not go too high or the service stops.. I have mine set to 768M and have had no issues.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby willm » Thu Dec 15, 2011 8:21 pm
Tried upping max-memory to 256. Still no good, still get the same error.
Thinking of ditching subsonic altogether, have never managed to get it working properly.
willm
Postby enedene » Wed Jan 25, 2012 1:06 am
I've just installed subsonic on my Ubuntu 11.10 server and I have the same problem.
The solution:
For some reason the /var/subsonic/transcode/lame is not working well. You need to install the lame on your system then put a link:
sudo apt-get install lame
sudo mv /var/subsonic/transcode/lame /var/subsonic/transcode/lame_backup
sudo ln -s /usr/bin/lame /var/subsonic/transcode/lame
That did it for me.
enedene
