Any way to remove duplicate cover art?
Postby subsonicRocks » Fri Dec 16, 2011 6:31 am
I noticed many of my folders have duplicate cover art. Here is a screenshot of what I'm talking about: http://i.imgur.com/zZ5hB.png Any way to remove the one that says "Change | Zoom" underneath it? Other folders don't have this duplicate cover art and I'm trying to make it look consistent over all folders. I thought it might have something to do with the hidden "Folder.jpg" or "AlbumArtSmall.jpg" files and tried different combinations of removing one/both from the folder with no change reflected in Subsonic. Any ideas? Thank you!
Using Subsonic 4.6 (build 2583) on Windows 7 x64.
subsonicRocks
Re: Any way to remove duplicate cover art?
Postby BKKKPewsey » Fri Dec 16, 2011 11:40 am
The example that you show appears to have the album art for that album duplicated within the artist folder.
SS will only show 1 album cover per folder - the hard part sometimes is getting it to show the right one :|
Postby subsonicRocks » Fri Dec 16, 2011 9:11 pm
The only other file besides music files and folders (including hidden) is "Folder.jpg". But if I remove "Folder.jpg", Subsonic displays no cover art in the root directory.
subsonicRocks
Postby BKKKPewsey » Fri Dec 16, 2011 10:59 pm
By root directory I assume you mean the artist directory?
If you have a folder.jpg there then SS will display it.
You would normally have the album art stored in the album directory :?
Users browsing this forum: No registered users and 72 guests
