Frequent Subsonic Crashes
Postby maxexcloo » Sun Dec 18, 2011 5:14 am
Since installing Subsonic 4.6 I've experienced frequent crashes.
The crashes seem to occur randomly and at least twice a day. They're very annoying as they interrupt my music and video streams and it would be awesome if we could work together towards solving the issues.
Problem Description: Subsonic crashes and either leaves me with a plain white screen or Java error.
Troubleshooting Steps: I've attempted removing the jetty directory and the thumbs directory.
Playback Application & Version: Subsonic 4.6, Web UI
Subsonic Version: 4.6 (build 2583) – December 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_26, Linux (145.0 MB / 205.8 MB)
Hardware Platform: Debian 6 x86_64
Java Memory Limit: 256 MB
Problem Filename: N/A
Output From ffmpeg -i:
main@data:~$ ffmpeg -i
ffmpeg version , Copyright (c) 2000-2011 the FFmpeg developers
  built on Nov 23 2011 10:13:59 with gcc 4.4.5
  configuration: --enable-libdc1394 --prefix=/usr --extra-cflags='-Wall -g ' --cc='ccache cc' --enable-shared --enable-libmp3lame --enable-gpl --enable-libvorbis --enable-pthreads --enable-libfaac --enable-libxvid --enable-postproc --enable-x11grab --enable-libgsm --enable-libtheora --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libx264 --enable-libspeex --enable-nonfree --disable-stripping --enable-avfilter --enable-libdirac --disable-decoder=libdirac --enable-libschroedinger --disable-encoder=libschroedinger --enable-version3 --enable-libopenjpeg --enable-libvpx --enable-librtmp --extra-libs=-lgcrypt --disable-altivec --disable-armv5te --disable-armv6 --disable-vis
  libavutil    50. 43. 0 / 50. 43. 0
  libavcodec   52.123. 0 / 52.123. 0
  libavformat  52.111. 0 / 52.111. 0
  libavdevice  52.  5. 0 / 52.  5. 0
  libavfilter   1. 80. 0 /  1. 80. 0
  libswscale    0. 14. 1 /  0. 14. 1
  libpostproc  51.  2. 0 / 51.  2. 0
Log Lines:
Finding it, I have to wait for another crash to get it...
Thanks for your support!
maxexcloo
Re: Frequent Subsonic Crashes
Postby ytechie » Thu Jan 05, 2012 10:55 pm
Just noticed this. If you start it up again, we may be able to resolve the issue. :)
ytechie
