Screenresolution 1024x768 - Player is not shown properly
Postby Frank » Tue Dec 20, 2011 5:20 pm
Hi everybody!
Subsonic is a great Thing, but got one Problem for me: All my Screens are 1024 x 768 and the left side of the player table is not shown on my Screen. I tested all the designs, but there is no solution for this. For my Resolution the Table with the Player should be divided with a line break. When I change my language settings to english, its short enough, but in German? No Chance.. I found the proper file for changing that, but struggled within a tricky Table. Can anyone help me to get the player table in a two line format?
greets and thanks
Frank
Frank
Re: Screenresolution 1024x768 - Player is not shown properly
Postby BKKKPewsey » Tue Dec 20, 2011 5:40 pm
I assume you mean the playlist - you should have a scroll bar in your browser at that bottom of the frame.
If that's not what you mean then can you post a screen shot showing the problem.
Postby Frank » Wed Dec 21, 2011 11:26 am
Hallo!
No, I do not mean the playlist. I mean the player-table.
As you can see - it ends with "settings", the rest is hidden outside the window. The Table of the Playlist is small enough.
I tried to expand the playlist to the left, but If I scroll the lower Window to the left, the Rest is missing.
Playlist with all Entrys:
greetz
Frank
Frank
Postby BKKKPewsey » Wed Dec 21, 2011 12:27 pm
Ok I can see the problem now. (Or should that be not see :? )
The only suggestions I can make, as a temp fix, is to change your page zoom settings within the browser.
I just tried in chrome @ 83% with your screen res. and that worked.
Alternatively try one of the player mods which replace the text fields with icons - check in the mods section.
You could pm Sindre with any suggestions to shorten the German translations in the player fields.
Postby Frank » Wed Dec 21, 2011 12:36 pm
I am sure, if I try out the other languages I will see it again.. I will have to use english as language or change the screen resolution temporarily if I want to use playlists :-)
Thanks so far..
greets
Frank
Frank
