Moving content folder and statistic lost
Postby gogogo » Wed Dec 21, 2011 1:12 am
i have moved today all folder to a raid system to preserve my data on an ubuntu server lts,
but after the new search update i have lost all db preference like comments, most listened, playlists, recent listen....etc...etc..!
There is a way to have back all?
Thanks. :shock:
gogogo
Re: Moving content folder and statistic lost
Postby BKKKPewsey » Wed Dec 21, 2011 1:29 am
Open up subsonic.script file (in db directory) with a text editor and see if the ratings etc are still there.
If they are you can update the paths to point to the new location and then restart SS.
Postby gogogo » Wed Dec 21, 2011 9:45 am
i have edited the subsonic.script but without results.
Can be that after the moving folder the .script file was changed totaly? if yes, i have more other version of the subsonic.script on my realtime incremental backup, i will can try to modified an old subsonic.script to see if it works?
Thanks.
Regards :)
gogogo
Postby gogogo » Wed Dec 21, 2011 10:01 am
Solved!
after restoring the subsonic.script old backup and changed all path with an find and paste, all works correctly with old satistics!
Thanks-you for the assistance.
Regards!
Music music music all day music! everywhere!
gogogo
Postby BKKKPewsey » Wed Dec 21, 2011 5:08 pm
:D
Just a reminder to all users to take note of this thread and backup your subsonic.script file before moving your collections.
If you don't you will probably lose your ratings, comments etc but a quick find and replace with a text editor on the backup will recover them.
Users browsing this forum: No registered users and 38 guests
