playbook app cuts off track numbers?
Postby copisen » Thu Dec 22, 2011 11:39 pm
hi there,
i browsed the forums for a while now but i couldnt find a proper answer on this one:
i use subsonic on the playbook to listen to audiobooks at night. all my files are named with numbers first in their filenames
in order to get them displayed in the right order.
however the playbook app seems to cut the numbers and sort the tracks aphabetically! this is unusuable for me,
might be ok if you dont insinst on the original track order of a music album but wont work at all if you want to
listen to an audiobook...
any solution on this?
i created playlists in windows but the app will find but not open them, ive read about the absolute playlist locations but there just has to be a more convenient way?
copisen
Re: playbook app cuts off track numbers?
Postby BKKKPewsey » Fri Dec 23, 2011 12:28 am
I would suggest you tag your music correctly using the ID tags. If the track numbers are correct then SS and. I presume the playbook. will show them in the correct order.
Most mediaplayers such as Mediamonkey or MP3tag will autotag from file name - see http://forum.subsonic.org/forum/viewtopic.php?f=6&t=8547
For any specific playbook questions you should contact the devs support@mirwindsor.com
