Errors in log file
Errors in log file
Postby jarome » Tue Dec 27, 2011 3:41 pm
On OpenSUSE 12.1, I get a lot of errors. Here are some of them:
[2011-11-30 03:00:04,446] INFO SearchService - Created search index with 47000 entries.
[2011-11-30 03:00:04,512] INFO SearchService - Created search index with 48000 entries.
[2011-11-30 03:00:04,571] INFO SearchService - Created search index with 49000 entries.
[2011-11-30 03:00:04,672] INFO SearchService - Created search index with 50000 entries.
[2011-11-30 03:00:04,758] INFO SearchService - Created search index with 51000 entries.
[2011-11-30 03:00:04,881] INFO SearchService - Created search index with 52000 entries.
[2011-11-30 03:00:04,954] INFO SearchService - Created search index with 53000 entries.
[2011-11-30 03:00:05,298] ERROR SearchService - An error occurred while reading index entry 'F ixYxi 1260296842000 ixYxi 1260296842000 ixYxi /data1/music/Martinu, Bohuslav/Cello Concertos Nos.1 and 2; Cello Concertino in C-; Czech Philharmonic Orchestra Orchestra, Raphael Wallfisch Cello, Jirí Belohlávek Conductor/Concertino in C- for Cello, Wind and Brass Ensemble, Percussion, and Piano H.143.mp3 ixYxi 19995195 ixYxi MARTINU, BOHUSLAV ixYxi CELLO CONCERTOS NOS.1 AND 2; CELLO CONCERTINO IN C-; CZECH PHILHARMONIC ORCHESTRA ORCHESTRA, RAPHAEL WALLFISCH CELLO, JIRÍ BELOHLÁVEK CONDUCTOR ixYxi CONCERTINO IN C- FOR CELLO, WIND AND BRASS ENSEMBLE, PERCUSSION, AND PIANO H.143'.
java.lang.ArrayIndexOutOfBoundsException
[2011-11-30 03:00:05,299] ERROR SearchService - An error occurred while reading index entry 'CONCERTINO IN C- FOR CELLO, WIND AND BRASS ENSEMBLE, PERCUSSION, AND PIANO H.143 ixYxi ixYxi Concerto'.
java.lang.NumberFormatException: For input string: ""
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
at java.lang.Long.parseLong(Long.java:450)
at java.lang.Long.parseLong(Long.java:478)
at net.sourceforge.subsonic.service.SearchService$Line.parse(SearchService.java:684)
at net.sourceforge.subsonic.service.SearchService.getIndex(SearchService.java:552)
at net.sourceforge.subsonic.service.SearchService.doCreateIndex(SearchService.java:153)
at net.sourceforge.subsonic.service.SearchService.access$000(SearchService.java:62)
at net.sourceforge.subsonic.service.SearchService$1.run(SearchService.java:115)
I get many cover art errors. I do not use cover art generally. Can I turn it off altogether?
[2011-11-30 21:38:42,794] WARN JaudiotaggerParser - Failed to find cover art tag in /data1/music/Bach, J. S/Cantatas BWV 62-64; Helmuth Rilling_ Stuttgart Bach Collegium, Gächinger Kantorei/._01 Bach_ Nun Komm Der Heiden Heiland BWV 62 - Nun Komm Der Heiden Heiland.mp3
org.jaudiotagger.audio.exceptions.InvalidAudioFrameException: No audio header found within._01 Bach_ Nun Komm Der Heiden Heiland BWV 62 - Nun Komm Der Heiden Heiland.mp3
at org.jaudiotagger.audio.mp3.MP3AudioHeader.<init>(MP3AudioHeader.java:138)
at org.jaudiotagger.audio.mp3.MP3File.<init>(MP3File.java:379)
at org.jaudiotagger.audio.mp3.MP3FileReader.read(MP3FileReader.java:39)
And lots of these:
[2011-12-26 19:37:31,541] WARN CoverArtController - Failed to create thumbnail for /data1/music/Bach, J. S/Suites for Solo Cello 1-4; Janos Starker/01 +Suite #1 in G Major Prelude.mp3
java.lang.Exception: Unable to decode image.
at net.sourceforge.subsonic.controller.CoverArtController.getCachedImage(CoverArtController.java:143)
at net.sourceforge.subsonic.controller.CoverArtController.handleRequest(CoverArtController.java:93)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:715)
jarome
Re: Errors in log file
Postby ytechie » Mon Jan 02, 2012 7:17 pm
Do the errors affect the operation of subsonic? If the indexer can't find things, that may be ok as long as everything else works fine.
ytechie
Postby jarome » Mon Jan 02, 2012 8:01 pm
ytechie wrote:Do the errors affect the operation of subsonic? If the indexer can't find things, that may be ok as long as everything else works fine.
I was more worried about the things array out of bounds. They can be used to break into the server!
jarome
Postby jarome » Tue Jan 03, 2012 5:01 pm
Is there a limit to the length of the path to the track, or its name?
jarome
Postby BKKKPewsey » Tue Jan 03, 2012 6:35 pm
I do not know for definite but I would imagine 254 characters
Postby jarome » Fri Jun 01, 2012 12:54 pm
There really should not be a limit....
jarome
