resolved
resolved
Postby gmd » Tue Dec 27, 2011 7:22 pm
Was Working fine for months suddenly stopped and continually get Status: gmd.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
turned off windows firewall forwarded ports on router tried upnp reinstalls of java and subsonic no joy running win7 ultimate and a huwaii hg532 router ports 8080 show as being forwarded when checked?
still get timeout message web browser goes to localhost and subsonic shows up fine,
any help greatly appreciated.
gmd
Re: Status: gmd.subsonic.org is registered, but could not co
Postby BKKKPewsey » Tue Dec 27, 2011 7:36 pm
Settings/network hit save - this will update the subsonic.org address.
Check with http://canyouseeme.org to make sure your port is still open
Also make sure that your server internal IP address has not changed. (static IP)
Postby gmd » Tue Dec 27, 2011 7:46 pm
Done all this loads of times
can you see me reports 8080 open and no problems static ip has been checked taken off and pu back on and checked again save/network just gives the timeout exception finds router ok though?
gmd
Postby gmd » Tue Dec 27, 2011 7:48 pm
[12/27/11 7:09:15 PM GMT]
[2011-12-28 12:22:55,085] INFO DaoHelper - Checking database schema.
[2011-12-28 12:22:55,598] INFO DaoHelper - Done checking database schema.
[2011-12-28 12:22:57,167] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Thu Dec 29 03:00:00 GMT 2011
[2011-12-28 12:22:57,245] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Wed Dec 28 12:27:57 GMT 2011
[2011-12-28 12:23:02,815] WARN NetworkService - Failed to delete port mapping.
net.sbbi.upnp.messages.UPNPResponseException: Detailed error code :501, Detailed error description :
at net.sbbi.upnp.messages.ActionMessageResponseParser.startElement(ActionMessageResponseParser.java:145)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at net.sbbi.upnp.messages.ActionMessage.service(ActionMessage.java:172)
at net.sbbi.upnp.impls.InternetGatewayDevice.deletePortMapping(InternetGatewayDevice.java:417)
at net.sourceforge.subsonic.domain.SBBIRouter.deletePortMapping(SBBIRouter.java:61)
at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:167)
at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:309)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRunAndReset(Unknown Source)
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
[2011-12-28 12:27:57,266] INFO PodcastService - Starting scheduled Podcast refresh.
[2011-12-28 12:27:57,266] INFO PodcastService - Completed scheduled Podcast refresh.
[2011-12-28 12:55:21,688] INFO VersionService - Resolved local Subsonic version to: 4.6
[2011-12-28 12:55:21,735] INFO PlayerDao - Created player 1.
[2011-12-28 12:55:22,000] INFO VersionService - Resolved latest Subsonic final version to: 4.6
[2011-12-28 12:55:22,000] INFO VersionService - Resolved latest Subsonic beta version to: 4.6.beta2
[2011-12-28 12:55:43,293] WARN NetworkService - Failed to delete port mapping.
gmd
Postby GJ51 » Tue Dec 27, 2011 8:56 pm
This webpage is not available
Google Chrome could not load the webpage because 92.26.221.255 took too long to respond. The website may be down, or you may be experiencing issues with your Internet connection.
Try rebooting your router. Check the IP address above to be sure that is still the IP from your ISP
Postby gmd » Tue Dec 27, 2011 9:08 pm
rebooted ip is 92.26.219.63
but still same problems
12/27/11 9:08:52 PM GMT]
WARN
NetworkService
gmd
Postby GJ51 » Tue Dec 27, 2011 9:13 pm
Your IP has changed. The new IP has to be resubmitted to the Subsonic.org server to update the redirection service.
EDIT:
http://92.26.219.63:8080/login.view;jse ... d2so6vt0fw Works OK.
Try going to the network settings and resending to Subsonic. Uncheck the Auto config, check the Access your server... block then click Save.
The failed to delete port mapping msg. may mean that you might have to manually edit the routing table on your router to ensure that the port forwarding tables are correct.
Postby gmd » Tue Dec 27, 2011 9:19 pm
Oops! Internet Explorer could not connect to 92.26.219.63:8080
Suggestions:
•Try reloading: 92.­26.­219.­63:­8080/­login.­view;jsessionid=­z3d2so6vt0fw
•Search on Google:
nope and everytime i resubmit it fails with the timeout exception
i take ii its network settings /save were talking about?
that sometimes brings me to the router webpage login
gmd
Postby GJ51 » Tue Dec 27, 2011 9:23 pm
Yes.
The warning that NETWORK Service has failed to delete port mapping may indicate that you need to reboot the host server and check any firewall entries.
I can get to your login page - no problem, using the ip:port#
Postby gmd » Tue Dec 27, 2011 9:26 pm
i have turned windows firewall on and off makes no difference reset to default and given subsonic all rights makes no difference.
What do you mean by rebooting host server? is that subsonic because i have stopped and started it and reinstalled with no joy.
gmd
Postby GJ51 » Tue Dec 27, 2011 9:29 pm
I just mean rebooting the host PC.
I just reregistered one of my sites and got "Status: maplegrovepartners.subsonic.org responded successfully, but could not authenticate it. "
Postby gmd » Tue Dec 27, 2011 9:31 pm
ahh right its been done several times but will give it another go ta!
gmd
Postby gmd » Tue Dec 27, 2011 9:40 pm
still the same after reboot time out exception[12/27/11 9:39:06 PM GMT]
WARN
NetworkService
gmd
Postby GJ51 » Tue Dec 27, 2011 9:42 pm
I can still get to your logon page. For some reason the ip isn't updating the SS redirect server. When I use gmd.subsonic.org, it returns your old ip address - http://92.26.221.255/
Postby gmd » Tue Dec 27, 2011 9:45 pm
which log on page you getting? i get my router logon page off ip and port
gmd
Users browsing this forum: No registered users and 93 guests
