Dual core at 100%
Dual core at 100%
Postby scottybuk » Wed Dec 28, 2011 12:30 pm
hi guys. ive been using subsonic on my ubuntu server to stream some video's in avi format. theres transcoding to flv.
as soon as i decide to play a video i notice both my cpu's hit 100% and stay there, after 20 mins or so into the video its gets all laggy and jumpy and i have to refresh the page and resume the video. (using web player).
when i check what process's are using what its not java that using all the cpu its ffmpeg. any ideas guys? i really want to use subsonic and buy a licence but if i cant solve this problem i cant use it.
look forward to your reply
scottybuk
Re: Dual core at 100%
Postby BKKKPewsey » Wed Dec 28, 2011 12:37 pm
scottybuk wrote:when i check what process's are using what its not java that using all the cpu its ffmpeg. any ideas guys?
Yes its because you are transcoding - your server hasn't got enough power to transcode on the fly.
Either convert to flv or ask santa for a more powerful server :)
Postby scottybuk » Wed Dec 28, 2011 12:41 pm
thanks for the fast reply. is thee any other method i could use with subsonic to use less cpu?
scottybuk
Postby BKKKPewsey » Wed Dec 28, 2011 12:57 pm
For videos either just stream flv's or mp4's which will show in the web player in native format or use an external player
and use the host pc to do any necessary transcoding.
Postby scottybuk » Wed Dec 28, 2011 1:44 pm
ok thanks. can you just confirm that my step 1 is correct or is there an alternative step 1 i can use that might increase performance. or maybe an alternative to ffmpeg?
ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -vcodec libx264 -preset superfast -threads 0 -
scottybuk
Postby ytechie » Wed Dec 28, 2011 9:18 pm
Maybe try playing around with the preset (superfast.) I use superfast, but it might be too much for your hardware to handle.
ytechie
Postby beyonder » Thu Dec 29, 2011 7:00 am
I am using Subsonic on a Phenom II 955. This is a quad core 3.2GHz chip. This is able to transcode my 1080p files for the web player using around 33-40% CPU power, just to give you an idea of how much processing power you actually need to use this feature.
I use the superfast preset as well, it is the subsonic default. "superfast" is the second fastest x264 preset, with "ultrafast" being the only one tuned for more speed. You may have some luck trying this out (just replace the "superfast" with "ultrafast" in your transcode settings).
beyonder
Postby Avarell_Dalton » Mon Jan 02, 2012 5:28 pm
To not be able to play video isn't a big deal for me but a good show off among my friends on their computers or on my Android so since I have the same problem as TS it would be interesting to hear what cpu is recommended. I'm running a Windows home server on a Core 2 Duo E6600 (2.40GHz,1066FSB,L2:4MB,rev.B2) with 2GB RAM. The specs a perfectly fine for the system and it's tasks except for ffmpeg.exe
It's still possible to upgrade hardware and for me I could go from 2.4GHz to just above 3GHz (or actually Pentium Extreme at 3.7GHz if there's still anyone out there) and RAM of course so the question is if it would make any change.
Sorry TS for kidnapping your thread :oops: at least I moved your thread to top :mrgreen:
Avarell_Dalton
Postby gogogo » Tue Jan 03, 2012 3:44 pm
hi transcode video on a single core 1.7ghz with 800 mb of ram,
my total cpu usage forever is of only 60% all time...!!!!!! simple...use cpulimit!!!!
http://ubuntuforums.org/showthread.php?t=992706
gogogo
Postby Avarell_Dalton » Tue Jan 03, 2012 10:55 pm
gogogo wrote:hi transcode video on a single core 1.7ghz with 800 mb of ram,
This is a a solution for Linux op, doesn't help me but it would be interesting to hear if you actually limit cpu time to ffmpeg?
Avarell_Dalton
Postby gogogo » Wed Jan 04, 2012 8:42 am
streaming video is always unstable, on my system i limit all process system to the 35%.
i have used subsonic on a server connected to the lan trough 1gbs & 100 mbit cables, wireless bridge g & 300mbps n, ethernet powerline ....but my stable (easy & simple) solutions is to use for the videos directly a system file share like samba or afp (under ubuntu for osx is more stable of the samba server!!!) http://goo.gl/fJnlm or directly on routers with ddwrt firmware with wireless n at least 300mps with hd directly connected throug usb to the router.
I'm using buffalo router http://goo.gl/a1Dfi
for cpulimit you simple try to set up a limit % and test if ffmpeg works:
apt-get install cpulimit
top or ps aux to see process pid or name
cpulimit -e ffmpeg -l 60% (as root)
on ubuntu use conky to see system statistics on the desktop...
other solution to avoid a transcoding on the fly is to set an automatic conversion ffmpeg script to .flv format whit a cronjob when a new video is added in a predetermined folder and move original video in a backup folder. http://goo.gl/wv3Kd and setting up an openvpn server on the ddwrt router to access files from wan.
good luck! :wink:
gogogo
Postby Avarell_Dalton » Wed Jan 04, 2012 7:16 pm
In my mind it seems odd to limit cpu time for a instance that uses up 100% of cpu time and make the conversion stutter but i'm no pro in this matter.
I use my file server to serve my Popcorn Hour and it does so flawlessly and of course to my computers as well. It would be stupid to use Subsonic to convert mkv files to mpeg before watching them in normal case but sometimes Subsonic is more suitable. To smartphones for example or when you just borrow your friends computer and want to show off.
Thanks for your reply anyway.
I still would like to hear what recommended hardware specs are for streaming video via Subsonic
Avarell_Dalton
Postby gogogo » Wed Jan 04, 2012 7:22 pm
gogogo
Postby Avarell_Dalton » Wed Jan 04, 2012 8:00 pm
I'm not sure if we don't understand each other but I do use a storage (my file server who uses SMB or Samba, don't remember what Microsoft uses, it is, as I said earlier, a Windows home server built on windows 2003 server).
I also use a GBit network with a Netgear GS716T ( http://support.netgear.com/app/products ... a_id/11708 ) switch and a router for DHCP and Internet connection. for wifi the router also servers as a access point at 108Mbit/s (as much as our phones can handle).
Every computer, every game console or media player is if possible connected to the network via cable. Not smartphones of course.
I am pretty sure the network is not the problem here, everything is directly connected to the switch (or tbh via a patch panel :s ) and everything was upgraded and overlooked last summer.
What I want is the file server to be able to convert video files on the fly via Subsonic, mine seems to lack of power to do so and therefore my question remains. What hardware does users here recommend for the server (who resides Subsonic)?
EDIT: Once again. I am sorry for kidnapping this thread from the thread starter!
Avarell_Dalton
Postby gogogo » Wed Jan 04, 2012 8:05 pm
switch to linux! :)
gogogo
Users browsing this forum: No registered users and 231 guests
