Search appears to be broken [Resolved]
Postby Mr. Odd » Sun Jan 01, 2012 4:14 am
Setup: Ubuntu 11.10, plenty of CPU and memory. Installation works fine - I can find everything from the library directly. Search, however, doesn't return anything for any entry. I've got into the control panel and forced an index rebuild but still nothing. Any suggestions?
Mr. Odd
Re: Search appears to be broken
Postby BKKKPewsey » Sun Jan 01, 2012 5:07 am
Mr. Odd wrote:I've got into the control panel and forced an index rebuild but still nothing.
I thought search update was done via settings/search - update search index :?
So what control panel are you referring to?
Does the log show any errors?
Postby Mr. Odd » Sun Jan 01, 2012 8:47 am
I'm referring to the Subsonic settings page (just habit calling it the 'control panel').
No errors in the log.
Mr. Odd
Postby BKKKPewsey » Sun Jan 01, 2012 5:09 pm
Mr. Odd wrote:No errors in the log.
Is there anything in log to show search index being created?
Last few lines should look like
[01/01/12 06:17:23 GMT]   INFO   SearchService   Created search index with 80000 entries.
[01/01/12 06:17:34 GMT]   INFO   SearchService   Created search index with 81000 entries.
[01/01/12 06:17:50 GMT]   INFO   SearchService   Updating Lucene search index.
[01/01/12 06:18:12 GMT]   INFO   SearchService   Created search index with 81521 entries.
Postby Mr. Odd » Sun Jan 01, 2012 6:06 pm
No, actually. The last line is:
[1/1/12 3:43:53 AM EST] INFO SearchService Created search index with 62000 entries
With no further entries. Any ideas why?
Mr. Odd
Postby BKKKPewsey » Sun Jan 01, 2012 6:48 pm
It looks like the search indexer is stopping before updating the Lucene database.
Check your java memory allocation and possibly up it.
You could also try deleting the sub-directories in the subsonic\lucene directories and re-building index (may have a corrupt db there)
Postby Mr. Odd » Sun Jan 01, 2012 8:14 pm
Yup, it was the java memory allocation. I doubled it and all's well. Thanks!
Mr. Odd
