Subsonic on HD Homerun
Postby kazman » Tue Jan 03, 2012 11:25 am
Hi I have been using Subsonic for over two months and it is great! I recently discovered that I could stream live TV using HD Homerun.
It seems to work fine for about 3 minutes then it just stops. I have copied the tail of the log file. Is there anything I am missing?
Also I can't seem to get the streaming of TV on android working has anyone else found this as an issue?
[1/3/12 9:57:18 PM EST]
DEBUG
InputStreamReaderThread
(/var/subsonic/transcode/ffmpeg) [buffer @ 0xad25040] w:720 h:576 pixfmt:yuv420p tb:1/1000000 sar:64/45 sws_param:
DEBUG
(/var/subsonic/transcode/ffmpeg) [scale @ 0xac1a160] w:720 h:576 fmt:yuv420p -> w:320 h:240 fmt:yuv420p flags:0x4
DEBUG
(/var/subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
DEBUG
(/var/subsonic/transcode/ffmpeg) Metadata:
DEBUG
(/var/subsonic/transcode/ffmpeg) encoder : Lavf53.6.0
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream #0.0: Video: flv, yuv420p, 320x240 [SAR 64:45 DAR 256:135], q=2-31, 400 kb/s, 1k tbn, 25 tbc
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream #0.1(eng): Audio: libmp3lame, 44100 Hz, 2 channels, s16, 64 kb/s
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream mapping:
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
DEBUG
(/var/subsonic/transcode/ffmpeg) Stream #0.1 -> #0.1
DEBUG
(/var/subsonic/transcode/ffmpeg) [mpeg2video @ 0xab7b9a0] warning: first frame is no keyframe
[1/3/12 9:59:48 PM EST]
DEBUG
(/var/subsonic/transcode/ffmpeg) [mpeg2video @ 0xab7b9a0] skipped MB in I frame at 23 22
DEBUG
(/var/subsonic/transcode/ffmpeg) [mpeg2video @ 0xab7b9a0] Warning MVs not available
DEBUG
(/var/subsonic/transcode/ffmpeg) [mpeg2video @ 0xab7b9a0] concealing 45 DC, 45 AC, 45 MV errors
kazman
