Vortexbox,subsonic>android SLOW
Postby wader » Tue Jan 03, 2012 5:11 pm
Ok, setup worked fine and subsonic is up and runing. Downloaded subsonic app to my android cellphone and can see all artists and songs. I can choose a song to play but jesus it takes forever. I thought it would be like direct stream like spotify but its not. Any clues to what's wrong?
wader
Re: Vortexbox,subsonic>android SLOW
Postby ytechie » Tue Jan 03, 2012 5:18 pm
What is your bandwidth like? Do you have cable, dsl, FiOS?
ytechie
Postby BKKKPewsey » Tue Jan 03, 2012 6:02 pm
wader wrote:Any clues to what's wrong?
With the information you have given us NO!
I suggest you read http://forum.subsonic.org/forum/viewtopic.php?f=2&t=5506
Postby wader » Tue Jan 03, 2012 8:13 pm
Problem Description: (A clear description of the problem including any error messages that you received in your playback application): See previous post.
Troubleshooting Steps: (A list of the steps you have taken to try to solve this problem yourself): Have no clue what so ever.
Playback Application and version: (The end application that you are using to stream from Subsonic): Downloaded app from market to my SE xperia Ray.
Subsonic Version: (copy/paste from the "About" screen in the Subsonic Web Interface): 4.6 (build 2585) – December 6, 2011
Server Version: (copy/paste from the "About" screen in the Subsonic Web Interface): jetty-6.1.x, java 1.6.0_22, Linux (46.4 MB / 74.6 MB)
Hardware Platform: (Windows, Mac, Linux, NAS Model, etc... Invclude version if applicable): Fedora release 16 (Verne)
Java Memory Limit: (Windows: found in the Subsonic Agent in the taskbar)
Problem Filename: (If you are having difficulty with a particular file, please include it's name)
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
Last ten log file lines: (The last ten or so lines copied and pasted from the About screen in the Subsonic Web Interface. Ideally these will be in a CODE block as well.) :
[1/3/12 6:03:56 PM CET] WARN CoverArtController Failed to create thumbnail for /storage/music/mp3/Aerosmith - Permanent Vacation (1987) [FLAC]/cover.jpg
[1/3/12 6:04:06 PM CET] WARN CoverArtController Failed to create thumbnail for /storage/music/mp3/Aerosmith - Permanent Vacation (1987) [FLAC]/cover.jpg
[1/3/12 6:04:16 PM CET] WARN CoverArtController Failed to create thumbnail for /storage/music/mp3/Aerosmith - Permanent Vacation (1987) [FLAC]/cover.jpg
[1/3/12 6:04:26 PM CET] WARN CoverArtController Failed to create thumbnail for /storage/music/mp3/Aerosmith - Permanent Vacation (1987) [FLAC]/cover.jpg
[1/3/12 6:04:36 PM CET] WARN CoverArtController Failed to create thumbnail for /storage/music/mp3/Aerosmith - Permanent Vacation (1987) [FLAC]/cover.jpg
[1/3/12 6:04:46 PM CET] WARN CoverArtController Failed to create thumbnail for /storage/music/mp3/Aerosmith - Permanent Vacation (1987) [FLAC]/cover.jpg
[1/3/12 6:04:56 PM CET] WARN CoverArtController Failed to create thumbnail for /storage/music/mp3/Aerosmith - Permanent Vacation (1987) [FLAC]/cover.jpg
[1/3/12 6:05:06 PM CET] WARN CoverArtController Failed to create thumbnail for /storage/music/mp3/Aerosmith - Permanent Vacation (1987) [FLAC]/cover.jpg
[1/3/12 6:12:41 PM CET] INFO StreamController Got range: Range[4328500,9223372036854775807]
[1/3/12 6:12:41 PM CET] INFO PlaylistInputStream admin listening to "Abba/Abba - Happy New Year.mp3"
[1/3/12 6:14:35 PM CET] WARN CoverArtController Failed to create thumbnail for /storage/music/mp3/Aerosmith - Permanent Vacation (1987) [FLAC]/cover.jpg
[1/3/12 6:40:31 PM CET] INFO NetworkService Successfully forwarding port 4040.
[1/3/12 7:40:35 PM CET] INFO NetworkService Successfully forwarding port 4040.
[1/3/12 8:40:38 PM CET] INFO NetworkService Successfully forwarding port 4040.
wader
Postby ytechie » Tue Jan 03, 2012 8:54 pm
What is your java memory limit? You left it out.
ytechie
Postby wader » Wed Jan 04, 2012 7:00 pm
On my phone or on the vortexbox, you have to be more specific if you'r asking.
wader
Postby wader » Wed Jan 04, 2012 9:13 pm
Vortexbox forum provided information and help to edit /etc/subsonic file.
wader
Users browsing this forum: No registered users and 92 guests
