stuttering play
stuttering play
Postby gmd » Tue Jan 03, 2012 5:43 pm
Plays 5 seconds at a time then stops downloads more then plays 5 seconds again and continues in this format only when accessed on my htc widfire on 3g fine on wireless network?
[2012-01-03 17:32:57,202] INFO DaoHelper - Checking database schema.
[2012-01-03 17:32:57,733] INFO DaoHelper - Done checking database schema.
[2012-01-03 17:32:58,107] INFO VersionService - Resolved local Subsonic version to: 4.6
[2012-01-03 17:32:58,684] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Wed Jan 04 03:00:00 GMT 2012
[2012-01-03 17:32:58,872] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Jan 03 17:37:58 GMT 2012
[2012-01-03 17:35:13,282] INFO NetworkService - Deleted port mapping for port 8081
[2012-01-03 17:35:20,302] INFO PlaylistInputStream - admin listening to "After Hours 3\The pointer Sisters - Send Him Back.mp3"
[2012-01-03 17:35:20,318] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\lame] [-S] [-h] [--resample] [44.1] [-b] [96] [--tt] [Send Him Back] [--ta] [The pointer Sisters] [--tl] [After Hours 3: More Northern Soul Masters] [N:\MP3_ALBUMS\A - F\After Hours 3\The pointer Sisters - Send Him Back.mp3] [-]
[2012-01-03 17:35:20,349] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) ID3v2 found. Be aware that the ID3 tag is currently lost when transcoding.
[2012-01-03 17:35:20,349] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) LAME version 3.96.1 (http://lame.sourceforge.net/)
[2012-01-03 17:35:20,349] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) CPU features: MMX (ASM used), 3DNow! (ASM used), SSE, SSE2
[2012-01-03 17:35:20,349] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Using polyphase lowpass filter, transition band: 15115 Hz - 15648 Hz
[2012-01-03 17:35:20,349] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Encoding N:\MP3_ALBUMS\A - F\After Hours 3\The pointer Sisters - Send Him Back.mp3
[2012-01-03 17:35:20,349] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) to <stdout>
[2012-01-03 17:35:20,349] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Encoding as 44.1 kHz 96 kbps j-stereo MPEG-1 Layer III (14.7x) qval=2
[2012-01-03 17:35:43,110] INFO StreamController - Got range: Range[2376,9223372036854775807]
[2012-01-03 17:35:43,125] INFO PlaylistInputStream - admin listening to "After Hours 3\The pointer Sisters - Send Him Back.mp3"
[2012-01-03 17:35:43,125] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\lame] [-S] [-h] [--resample] [44.1] [-b] [96] [--tt] [Send Him Back] [--ta] [The pointer Sisters] [--tl] [After Hours 3: More Northern Soul Masters] [N:\MP3_ALBUMS\A - F\After Hours 3\The pointer Sisters - Send Him Back.mp3] [-]
[2012-01-03 17:35:43,141] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) ID3v2 found. Be aware that the ID3 tag is currently lost when transcoding.
[2012-01-03 17:35:43,141] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) LAME version 3.96.1 (http://lame.sourceforge.net/)
[2012-01-03 17:35:43,141] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) CPU features: MMX (ASM used), 3DNow! (ASM used), SSE, SSE2
[2012-01-03 17:35:43,141] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Using polyphase lowpass filter, transition band: 15115 Hz - 15648 Hz
[2012-01-03 17:35:43,141] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Encoding N:\MP3_ALBUMS\A - F\After Hours 3\The pointer Sisters - Send Him Back.mp3
[2012-01-03 17:35:43,141] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) to <stdout>
[2012-01-03 17:35:43,141] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Encoding as 44.1 kHz 96 kbps j-stereo MPEG-1 Layer III (14.7x) qval=2
[2012-01-03 17:35:45,138] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\lame) Error writing mp3 output
[2012-01-03 17:37:58,892] INFO PodcastService - Starting scheduled Podcast refresh.
[2012-01-03 17:37:58,892] INFO PodcastService - Completed scheduled Podcast refresh.
[2012-01-03 17:39:38,519] INFO VersionService - Resolved latest Subsonic final version to: 4.6
[2012-01-03 17:39:38,519] INFO VersionService - Resolved latest Subsonic beta version to: 4.6.beta2
gmd
Re: stuttering play
Postby ytechie » Wed Jan 04, 2012 5:43 pm
What is your upload bandwidth like? If it is slow, then bingo! There is your problem!
ytechie
Re: stuttering play
Postby gmd » Sun Jan 08, 2012 1:05 pm
1004(kbit/s) should work surely?
gmd
Re: stuttering play
Postby BKKKPewsey » Sun Jan 08, 2012 1:24 pm
That should be good enough for mp3's - see if you can test from outside your lan on another pc
eg. keep the 3G provider out of the equation
If it works ok then you will know where the bottleneck is.
Re: stuttering play
Postby gmd » Tue Jan 10, 2012 9:03 pm
Resolved bottlenecks with 3g ok on hsdpa shame that theres no way of increasing the cache on android player to delay start as runs fine on 3g once well in front!
gmd
