I am running 4.6 (build 2583) on Win08 R2.
Just curious if there is a way to clear the "Most Played" albums section for it to reset and start over? I just wanted to clear it with the start of 2012. Thanks for any help!
but some abuse the privilege!BKKKPewsey wrote:If you want to reset your all your album play counts to 0 then you can do this easily via db.view.
See viewtopic.php?f=2&t=7857&p=31452&hilit=database#p31452
for more info but basically you need to issue "update music_file_info set play_count=0"
ytechie wrote:If you pull the plug, when you start it up again, things may not be the way they are supposed to. Just saying.
but some abuse the privilege!Users browsing this forum: No registered users and 40 guests
