Clean Search index
Clean Search index
Postby toif » Mon Jan 09, 2012 3:24 pm
Hello all,
I have subsonic installed on QNAP TS-410 NAS and working fine so far, except the search function. When I try to search for anything, either it gives no result or show some results referring to very old folder structure. I have currently "music/_P/Pearl Jam/[2000] Binaural/01 - Pearl Jam - Insignificance.mp3" like folder structure. I tried manually update search index from settings but didn't work for me. I also tried deleting Lucene folder but didn't work either. So, how am I gonna rebuild a clean search index for my database. Which folders I should remove and rescan?
thanks.
toif
Re: Clean Search index
Postby BKKKPewsey » Mon Jan 09, 2012 4:25 pm
The subsonic##.index file is the main database for the music records.
If you delete that and the lucene folders that should give you a clean slate to work with.
