android app plays a few secs and skips to next song
Postby bytethdgroove » Wed Jan 11, 2012 12:03 am
after I updated to most recent version of the android app, everytime I try to listen to music (that hasnt already been cached) it plays a few seconds and then skips to the next song.
at first I thought maybe my car was doing somethig, so I repaird my bluetooth, unistalled subsonic app and resinstalled, deleted the player from the server, to no avail.
web version works, just android thats giving me problems. for some reason I thinking it has to do with android itself, am i missing a setting somewhere?
please help. making a nandoid backup and going to reflash my phone...keeping fingers crossed.
thanks
byte
"I'm as honest as the day is long, the longer the daylight the less I do wrong!"
bytethdgroove
Re: android app plays a few secs and skips to next song
Postby bytethdgroove » Wed Jan 11, 2012 12:12 am
version: 4.6 (build 2583) – December 6, 2011
jetty-6.1.x, java 1.6.0_29, Windows 2003 (83.7 MB / 209.4 MB)
android app 3.3
android 2.3.4
phone motorola electrify
I should note that ther is nothing in the log that shows any kind of error
here is a sample of the log:
[2012-01-10 15:05:38,397] INFO PlaylistInputStream - bytethegroove listening to "2009 - In the Ocean\01 - Keep My Head High.mp3"
[2012-01-10 15:05:45,241] INFO PlaylistInputStream - bytethegroove listening to "2009 - In the Ocean\02 - All Night.mp3"
bytethdgroove
Postby bytethdgroove » Thu Jan 12, 2012 1:53 pm
reflashed phone, reinstalled subsonic server.
still same problem everytime I try to play a song,
so friggen annoying
bytethdgroove
Postby adkjunkie » Mon Jan 16, 2012 5:31 pm
I have a similar issue on my Motorola Droid X2:
When I start playing a new album, I'll immediately pause the first song until it's completely cached. Then when I play it, it'll go about 30 seconds before skipping to the next song. I then skip it back and it plays fine.
A little obnoxious but workable.
adkjunkie
Postby bytethdgroove » Tue Jan 17, 2012 12:44 am
figured the same thing out today.
really annoying.
is this a moto thing?
all my other friends on non moto phones have no issue.
got my phone in nov, swear it was working fine, but now it seems like atleast month since it worked properly, so possibly a moto issue?
at first I though it was playing faster than it downloaded, but confirmed that is not the case as mine was 2.5mb downloaded and only 15 secs into the song, when it skipped to the next song.
and the log (i posted above) shows no errors
peace
byte
bytethdgroove
Postby bytethdgroove » Tue Jan 17, 2012 12:46 am
just had a thought, if it is a moto issue, im going to try flashing a non blur rom (ie cm9 or miui) and see if th problem persists
will report back
btw are u on a stock rom?
peace
byte
bytethdgroove
Postby steveh_131 » Tue Jan 17, 2012 5:52 pm
I'm having this same problem. Rooted HTC Inspire.
It may skip at the very beginning or it may be towards the end, but it won't finish a song.
steveh_131
Postby steveh_131 » Tue Jan 17, 2012 6:24 pm
Found this thread: http://forum.subsonic.org/forum/viewtopic.php?f=2&t=8307
According to this, you can go into your subsonic server settings and change the android player type from "external player" to "web player" and it eliminates this problem.
I just did this and have played through a few songs with no skipping, so I hope this helps some of you too!
steveh_131
Postby bytethdgroove » Tue Jan 17, 2012 7:41 pm
Yes....I love you man...this work around mentioned in the link above worked for me. This changes the outcome of my entire day...you rock
Peace
Byte
Sent from my Motorola Electrify using Tapatalk
bytethdgroove
Postby steveh_131 » Wed Jan 18, 2012 8:46 pm
I'm glad it worked well for you.
It worked great yesterday, but today its hit or miss. It's definitely better, but occasionally it still skips through songs. But it's much better than it was.
steveh_131
Postby bytethdgroove » Wed Jan 18, 2012 9:36 pm
Yea worked all day after I changed to Web player yesterday, but today its back to buggin out...tried changing back and forth between Web player and external...but both skip songs.....this sucks.....
I wish I knew more code...
Hope the dev is atleast sees we are having issues....u never realize how much you value something until its not working :(
Byte
bytethdgroove
Postby bytethdgroove » Thu Jan 19, 2012 1:39 pm
There something definitely wrong with the Android app...I've seen 4 new topics, all slightly different issues...end result....there are many of us Android users experiencing problems...
I wish the ics version worked for 2.3.5, then I would have something else to try
Peace
Byte
bytethdgroove
Postby chugmonkey » Thu Jan 19, 2012 3:15 pm
bytethdgroove wrote:There something definitely wrong with the Android app...I've seen 4 new topics, all slightly different issues...end result....there are many of us Android users experiencing problems...
Peace
Byte
Are you confident this is nothing to do with your MNO restricting your data usage? Perhaps run subsonic off a different port, even SSL, to see if encrypting your traffic makes any difference. Throttling and interrupting of web traffic is happening with increasing frequency in the UK/US to ensure QoS for other network users.
chugmonkey
Postby steveh_131 » Thu Jan 19, 2012 3:20 pm
chugmonkey wrote:Are you confident this is nothing to do with your MNO restricting your data usage? Perhaps run subsonic off a different port, even SSL, to see if encrypting your traffic makes any difference. Throttling and interrupting of web traffic is happening with increasing frequency in the UK/US to ensure QoS for other network users.
I've run it from home on WiFi and had the same issues. I can try it again, but direct it to the local node instead of my outside IP address to eliminate my home ISP as well.
Although this doesn't really make sense as the issue since Subsonic is actually downloading the files completely. They are there on the memory card and can be played. It just skips through them for some reason.
steveh_131
Postby bytethdgroove » Thu Jan 19, 2012 6:57 pm
I'm confident its not a carrier issue.
As other users on the same carrier have no issues.... I think its more related to Android os....version 2.3.5
Same thing happens to me when on wifi....
BYTE
bytethdgroove
