Jukebox Mode Explanation
Postby TPrime » Wed Jan 11, 2012 11:45 pm
Hi, after messing around with Subsonic I've decided that it's amazing. However I have no idea how the Jukebox mode is supposed to work. Could someone give me the rundown from step 1?
TPrime
Re: Jukebox Mode Explanation
Postby BKKKPewsey » Thu Jan 12, 2012 3:41 am
Simple
If you have a sound card on your server it will output the music via that.
But you still control it via the web interface of the client pc.
Think of it as an advanced remote control :)
I have my server linked to my a/v amp and control whats playing from me lappie.
Postby TPrime » Thu Jan 12, 2012 7:56 pm
UPDATE:Problem solved. It was a problem with openJDK. I replaced it with the official Oracle JDK and now all works well.
That's about what I figured. So the problem is I can't get anything to play. If I use the web player it works fine on the server, but when I switch to jukebox I get nothing. I suppose it doesn't matter with the set up I'm using except that I want to use the "play more random songs at end of playlist" feature.
Any ideas what could be wrong?
TPrime
Re: SOLVED! Jukebox Mode Explanation
Postby TPrime » Sun Jan 15, 2012 2:15 am
Discovered a new issue. I can do the jukebox, but when I check the "Play more random songs when end of playlist is reached." box it doesn't do anything at the end of the play list.... Isn't it supposed to?
TPrime
Postby piethein » Wed Jan 25, 2012 10:37 am
I think it would be neat to be able to control the android app from a PC/other device. The playback android device could be connected to an amplifier somewhere and another device could control it.
piethein
