Subsonic won't play a song - website
Postby klaauser » Thu Jan 12, 2012 8:28 pm
Hi all -
This happens to me at least once a day. I will be listening to an album in subsonic (OS X 10.7 - Chrome) and it will stop mid song. When I try to play again, it looks like it's trying to cache the song for about 1 second and then fails and won't play the song. Usually this propagates to the rest of the album and I cannot listen to any song on that album any more.
I am assuming this has something to do with the cache because if I open up incognito mode (doesn't store cookies or cache), it works just fine.
Anyone having the same issue/a fix??
KL
klaauser
Re: Subsonic won't play a song - website
Postby BKKKPewsey » Thu Jan 12, 2012 9:15 pm
which version of SS are you using?
Postby ytechie » Fri Jan 13, 2012 12:49 am
I have the same issue occasionally. Just go ahead and clear the cache and everything should be fine. I can replicate the behavior if I press the song link over and over in quick succession. I think it just confuses the cache. :|
ytechie
Postby klaauser » Fri Jan 13, 2012 2:06 am
Version 4.6 (build 2583) – December 6, 2011
Server jetty-6.1.x, java 1.6.0_29, Windows 7 (73.4 MB / 96.7 MB)
klaauser
Postby ytechie » Sun Jan 15, 2012 10:20 am
Have a look at this: viewtopic.php?f=8&t=8749
ytechie
Postby klaauser » Thu Jan 19, 2012 7:41 pm
that worked!! Thanks a ton :)
klaauser
