Subsonic: How to clear cache?
Postby Jabba-deHut » Thu Jan 12, 2012 8:43 pm
Hi all,
I use Subsonic to hear Audiobooks, but sometimes it reapeat the same track every time (and ist not the repeat button :D ), allthought I select an other track behind this track. Subsonic purported it plays an other Track with other length, but I hear the same. :(
Tracks who I played before are OK, but no later one. :(
Subsonic shows me that all Tracks cached finaly, but the fiesystem ("OI Filemanager") says that only those files exists, that I can play. OK, thats make sense, but Subsonic means the files exists and don't download them again. I try to delet them manuel, but subsonic shows the Files as cached, furthermore. It downloads only the first track again, then the download stops and its play only the first one, permanently :(
In the Serverlogs the Songs don't appear again, so I think the Client has a cachefile outside of the cache folder, where Subsonic enter his cached files, or not?
Where is it, and can I delete it?
Could you fix this bug, please. Otherwise add an "Clean cache file Button", please! ;)
Tell me what Info you need, and I post it (or better send it per mail). ;)
Jabba-deHut
Re: Subsonic: How to clear cache?
Postby BKKKPewsey » Thu Jan 12, 2012 9:13 pm
First thing have a read of viewtopic.php?f=2&t=5506
It would appear that you are trying to play back on some sort of mobile device :?
Postby Jabba-deHut » Fri Jan 13, 2012 1:10 pm
Sorry, of course:
Problem Description: some Files shown as cached, but they aren't and Subsonic repeats only the last playable track.
Troubleshooting Steps: Restart Server and Handyapp, delete all cached files, clear search history, changed Dir and play other Song
Playback Application and version: Subsonic for Android (actual Version)
Subsonic Version:Version 4.6 (build 2583) – 6. Dezember 2011
Server Version: Server jetty-6.1.x, java 1.6.0_29, Windows 7 (109,7 MB / 287,2 MB)
Hardware Platform: (Windows 7 Ultimate, all Updates installed)
Java Memory Limit: (400MB, same Error with 100MB)
Output from ffmpeg -i:
C:\subsonic\transcode>ffmpeg -i "D:\Hörspiele\Stephen.King.-.Wahn\0312.mp3" >> o
ut.txt
ffmpeg version N-31653-gfaa3381, Copyright (c) 2000-2011 the FFmpeg developers
  built on Jul 28 2011 01:57:12 with gcc 4.6.1
  configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-
runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libo
pencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --
enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger
--enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enabl
e-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil    51. 11. 0 / 51. 11. 0
  libavcodec   53.  9. 0 / 53.  9. 0
  libavformat  53.  6. 0 / 53.  6. 0
  libavdevice  53.  2. 0 / 53.  2. 0
  libavfilter   2. 27. 3 /  2. 27. 3
  libswscale    2.  0. 0 /  2.  0. 0
  libpostproc  51.  2. 0 / 51.  2. 0
[mp3 @ 01BA9D20] max_analyze_duration 5000000 reached at 5015510
[mp3 @ 01BA9D20] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from 'D:\H├Ârspiele\Stephen.King.-.Wahn\0312.mp3':
  Metadata:
    title           : none
    artist          : Stephen King
    album           : Wahn CD3
    date            : 2008
    comment         : none
    track           : 12
  Duration: 00:04:50.67, start: 0.000000, bitrate: 80 kb/s
    Stream #0.0: Audio: mp3, 22050 Hz, stereo, s16, 80 kb/s
Last ten log file lines:
[2012-01-12 03:20:23,175] INFO DaoHelper - Checking database schema.
[2012-01-12 03:20:24,517] INFO DaoHelper - Done checking database schema.
[2012-01-12 03:20:24,907] INFO VersionService - Resolved local Subsonic version to: 4.6
[2012-01-12 03:20:25,531] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Fri Jan 13 03:00:00 CET 2012
[2012-01-12 03:20:25,671] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Thu Jan 12 03:25:25 CET 2012
[2012-01-12 03:25:25,667] INFO PodcastService - Starting scheduled Podcast refresh.
[2012-01-12 03:25:25,667] INFO PodcastService - Completed scheduled Podcast refresh.
[2012-01-12 20:29:10,887] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0902.mp3"
[2012-01-12 20:29:10,887] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0101.mp3"
[2012-01-12 20:29:14,257] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0902.mp3"
[2012-01-12 20:29:19,249] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0103.mp3"
[2012-01-12 20:29:26,518] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0104.mp3"
[2012-01-12 20:29:31,666] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0105.mp3"
[2012-01-12 20:29:35,878] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0101.mp3"
[2012-01-12 20:29:41,744] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0106.mp3"
[2012-01-12 20:29:46,752] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0107.mp3"
[2012-01-12 20:29:51,822] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0108.mp3"
[2012-01-12 20:29:56,907] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0109.mp3"
[2012-01-12 20:30:02,086] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0110.mp3"
[2012-01-12 20:30:07,172] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0111.mp3"
[2012-01-12 20:30:26,875] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0111.mp3"
[2012-01-12 20:30:37,639] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0212.mp3"
[2012-01-12 20:30:42,771] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0213.mp3"
[2012-01-12 20:30:47,841] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\1714.mp3"
[2012-01-12 20:39:11,254] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0501.mp3"
[2012-01-12 20:39:16,309] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0102.mp3"
[2012-01-12 20:39:21,332] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0103.mp3"
[2012-01-12 20:39:26,355] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0104.mp3"
[2012-01-12 20:39:31,409] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0105.mp3"
[2012-01-12 20:40:01,954] INFO PlaylistInputStream - admin listening to "Agent.Smith.-.01.-.Genetic.Code.Mp3.192.KBit\Genetic Code 01.mp3"
[2012-01-12 20:40:27,725] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0106.mp3"
[2012-01-12 20:40:31,641] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0107.mp3"
[2012-01-12 20:40:38,146] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0108.mp3"
[2012-01-12 20:41:51,685] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0108.mp3"
[2012-01-12 20:41:55,647] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0109.mp3"
[2012-01-12 20:42:03,354] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0110.mp3"
[2012-01-12 20:42:08,517] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0111.mp3"
[2012-01-12 20:42:13,650] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0212.mp3"
[2012-01-12 20:42:18,688] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\0213.mp3"
[2012-01-12 20:42:23,852] INFO PlaylistInputStream - admin listening to "Stephen.King.-.Wahn\1714.mp3"
[2012-01-12 20:57:34,488] INFO PlayerDao - Created player 6.
[2012-01-12 20:58:26,967] INFO VersionService - Resolved latest Subsonic final version to: 4.6
[2012-01-12 20:58:26,967] INFO VersionService - Resolved latest Subsonic beta version to: 4.6.beta2
[2012-01-12 21:21:25,838] INFO NetworkService - Successfully forwarding port 82.
[2012-01-12 21:29:05,509] INFO PlaylistInputStream - admin listening to "A.J.Kazinski.-.Die.Auserwaehlten.Mp3.Vbr\001 - Kapitel 001.mp3"
[2012-01-13 03:00:00,542] INFO SearchService - Starting to create search index.
[2012-01-13 03:00:02,305] INFO SearchService - Created search index with 1000 entries.
[2012-01-13 03:00:03,693] INFO SearchService - Created search index with 2000 entries.
[2012-01-13 03:00:04,894] INFO SearchService - Created search index with 3000 entries.
[2012-01-13 03:00:06,189] INFO SearchService - Created search index with 4000 entries.
[2012-01-13 03:00:08,046] INFO SearchService - Created search index with 5000 entries.
[2012-01-13 03:00:11,010] INFO SearchService - Created search index with 6000 entries.
[2012-01-13 03:00:12,570] INFO SearchService - Created search index with 7000 entries.
[2012-01-13 03:00:13,896] INFO SearchService - Created search index with 8000 entries.
[2012-01-13 03:00:14,988] INFO SearchService - Created search index with 9000 entries.
[2012-01-13 03:00:16,064] INFO SearchService - Created search index with 10000 entries.
[2012-01-13 03:00:17,733] INFO SearchService - Created search index with 11000 entries.
[2012-01-13 03:00:19,090] INFO SearchService - Created search index with 12000 entries.
[2012-01-13 03:00:20,307] INFO SearchService - Created search index with 13000 entries.
[2012-01-13 03:00:22,117] INFO SearchService - Created search index with 14000 entries.
[2012-01-13 03:00:23,552] INFO SearchService - Created search index with 15000 entries.
[2012-01-13 03:00:24,800] INFO SearchService - Created search index with 16000 entries.
[2012-01-13 03:00:26,875] INFO SearchService - Created search index with 17000 entries.
[2012-01-13 03:00:28,310] INFO SearchService - Created search index with 18000 entries.
[2012-01-13 03:00:29,745] INFO SearchService - Created search index with 19000 entries.
[2012-01-13 03:00:31,196] INFO SearchService - Created search index with 20000 entries.
[2012-01-13 03:00:32,506] INFO SearchService - Created search index with 21000 entries.
[2012-01-13 03:00:33,832] INFO SearchService - Created search index with 22000 entries.
[2012-01-13 03:00:35,143] INFO SearchService - Created search index with 23000 entries.
[2012-01-13 03:00:36,687] INFO SearchService - Created search index with 24000 entries.
[2012-01-13 03:00:38,388] INFO SearchService - Created search index with 25000 entries.
[2012-01-13 03:00:40,150] INFO SearchService - Created search index with 26000 entries.
[2012-01-13 03:00:41,695] INFO SearchService - Created search index with 27000 entries.
[2012-01-13 03:00:43,816] INFO SearchService - Created search index with 28000 entries.
[2012-01-13 03:00:45,626] INFO SearchService - Created search index with 29000 entries.
[2012-01-13 03:00:47,280] INFO SearchService - Created search index with 30000 entries.
[2012-01-13 03:00:48,902] INFO SearchService - Created search index with 31000 entries.
[2012-01-13 03:00:50,446] INFO SearchService - Created search index with 32000 entries.
[2012-01-13 03:00:51,850] INFO SearchService - Created search index with 33000 entries.
[2012-01-13 03:00:53,660] INFO SearchService - Created search index with 34000 entries.
[2012-01-13 03:00:55,267] INFO SearchService - Created search index with 35000 entries.
[2012-01-13 03:00:56,749] INFO SearchService - Created search index with 36000 entries.
[2012-01-13 03:00:58,340] INFO SearchService - Created search index with 37000 entries.
[2012-01-13 03:00:59,370] INFO SearchService - Created search index with 38000 entries.
[2012-01-13 03:01:00,727] INFO SearchService - Created search index with 39000 entries.
[2012-01-13 03:01:01,990] INFO SearchService - Created search index with 40000 entries.
[2012-01-13 03:01:03,254] INFO SearchService - Created search index with 41000 entries.
[2012-01-13 03:01:04,424] INFO SearchService - Created search index with 42000 entries.
[2012-01-13 03:01:06,046] INFO SearchService - Created search index with 43000 entries.
[2012-01-13 03:01:07,575] INFO SearchService - Created search index with 44000 entries.
[2012-01-13 03:01:08,636] INFO SearchService - Created search index with 45000 entries.
[2012-01-13 03:01:10,212] INFO SearchService - Created search index with 46000 entries.
[2012-01-13 03:01:11,600] INFO SearchService - Created search index with 47000 entries.
[2012-01-13 03:01:13,066] INFO SearchService - Created search index with 48000 entries.
[2012-01-13 03:01:14,767] INFO SearchService - Created search index with 49000 entries.
[2012-01-13 03:01:16,327] INFO SearchService - Created search index with 50000 entries.
[2012-01-13 03:01:17,434] INFO SearchService - Created search index with 51000 entries.
[2012-01-13 03:01:18,745] INFO SearchService - Created search index with 52000 entries.
[2012-01-13 03:01:19,962] INFO SearchService - Created search index with 53000 entries.
[2012-01-13 03:01:21,506] INFO SearchService - Created search index with 54000 entries.
[2012-01-13 03:01:22,957] INFO SearchService - Created search index with 55000 entries.
[2012-01-13 03:01:24,392] INFO SearchService - Created search index with 56000 entries.
[2012-01-13 03:01:26,280] INFO SearchService - Created search index with 57000 entries.
[2012-01-13 03:01:27,933] INFO SearchService - Created search index with 58000 entries.
[2012-01-13 03:01:29,883] INFO SearchService - Created search index with 59000 entries.
[2012-01-13 03:01:31,428] INFO SearchService - Created search index with 60000 entries.
[2012-01-13 03:01:32,629] INFO SearchService - Created search index with 61000 entries.
[2012-01-13 03:01:33,939] INFO SearchService - Created search index with 62000 entries.
[2012-01-13 03:01:35,219] INFO SearchService - Created search index with 63000 entries.
[2012-01-13 03:01:36,794] INFO SearchService - Created search index with 64000 entries.
[2012-01-13 03:01:38,339] INFO SearchService - Created search index with 65000 entries.
[2012-01-13 03:01:39,571] INFO SearchService - Created search index with 66000 entries.
[2012-01-13 03:01:41,069] INFO SearchService - Created search index with 67000 entries.
[2012-01-13 03:01:42,675] INFO SearchService - Created search index with 68000 entries.
[2012-01-13 03:01:43,892] INFO SearchService - Created search index with 69000 entries.
[2012-01-13 03:01:45,156] INFO SearchService - Created search index with 70000 entries.
[2012-01-13 03:01:46,544] INFO SearchService - Created search index with 71000 entries.
[2012-01-13 03:01:48,338] INFO SearchService - Created search index with 72000 entries.
[2012-01-13 03:01:50,085] INFO SearchService - Created search index with 73000 entries.
[2012-01-13 03:01:52,878] INFO SearchService - Created search index with 74000 entries.
[2012-01-13 03:01:55,733] INFO SearchService - Created search index with 75000 entries.
[2012-01-13 03:02:00,647] INFO SearchService - Updating Lucene search index.
[2012-01-13 03:02:06,762] INFO SearchService - Created search index with 75747 entries.
[2012-01-13 03:21:44,736] INFO NetworkService - Successfully forwarding port 82.
[2012-01-13 03:25:26,272] INFO PodcastService - Starting scheduled Podcast refresh.
[2012-01-13 03:25:26,272] INFO PodcastService - Completed scheduled Podcast refresh.
Jabba-deHut
Postby BKKKPewsey » Fri Jan 13, 2012 3:07 pm
Ok there appears to be no problem at the server end from what I can see in the log.
Therefore it would to be a problem with your playback device - which is?
All we know at that moment is it's an Android something :)
If you tell us what you are playing on then hopefully another user with the same device can help out.
Postby Jabba-deHut » Fri Jan 13, 2012 4:04 pm
You don't have an magic crystal ball? ;-)
I used an Samsung Galaxy S2 (GT-I9100),
with Andrioid 2.3.5 Baseband i9100buki1
on Kernel 2.6.35.7-i9100bukj3-cl647431
Build-Nr: gingerbread.bukj3
My SubSonic has an license and I used different Serveradresses for the same Server (LAN/WAN).
Jabba-deHut
Postby bushman4 » Fri Jan 13, 2012 4:12 pm
I can't tell you what the answer is to your main problem, but I can tell you that, if you are using the Subsonic.org redirect service, this is unnecessary... it makes the determination automatically based on where you are trying to connect from... if you are on your LAN you are redirected to your internal address, and if not, you are redirected to the external one.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Jabba-deHut » Sat Jan 14, 2012 9:17 pm
Thats nice to know, but it doesn't help me, now. ;-)
Did noboby know where Subsonic save the cachestatus?
Jabba-deHut
