Disable a user from using a subsonic app?
Postby burner247 » Fri Jan 13, 2012 2:26 am
Hello, i have a guess user account for streaming music only. Is there also a way to block them from using any of the subsonic apps?
burner247
Re: Disable a user from using a subsonic app?
Postby BKKKPewsey » Fri Jan 13, 2012 2:39 am
I am fairly certain the answer is no without modding.
So you want to disable the api for a named user - the trouble with that is that will stop them using other apps
eg perisonic etc - is that what you want?
I must ask why though ? are you trying to prevent them from caching the music?
Postby burner247 » Fri Jan 13, 2012 2:58 am
Well since guest can only stream they wouldn't be able to cache songs with any app correct? Hmmm not sure what I want to do now, will think about it.
burner247
Postby burner247 » Mon Jan 16, 2012 7:27 pm
Ok so downloads rights are disabled from my guest user account. but from the isub app logged in as a guest downloads are allowed. How is that?
burner247
Postby ytechie » Mon Jan 16, 2012 9:45 pm
That isn't downloading. That's caching. Caching just means that the user won't have to wait for the file to load before playing.
ytechie
