port forwarding
port forwarding
Postby JFM » Wed Jan 18, 2012 2:26 am
Having a bit of an issue. Using teamviewer which runs on port 80 just fine, but can't configure subsonic on that. Have tried ports 8080 and 4040 to no avail and was wondering what I need to do.
I'm using a cisco e2500 router and I just need to know what I'm doing wrong with forwarding. I keep getting connection time out. Running windows 7 64 bit.
JFM
Re: port forwarding
Postby ytechie » Thu Jan 19, 2012 3:22 am
First go to canyouseeme.org and check for two-way on the port you want subsonic to operate on.
ytechie
Re: port forwarding
Postby GJ51 » Thu Jan 19, 2012 4:01 am
Re: port forwarding
Postby JFM » Thu Jan 19, 2012 4:40 am
Thanks. Got that issue taken care of now I can access subsonic outside of lan, but not on any other computer on the lan or wifi device for that matter. I have isub for my iphone and I switch to 3g and can stream all day, but nothing if I type in my address on any other machine in the house. I've got windows 7 firewall configured to private for all subsonic services. Do I need to change this?
JFM
Re: port forwarding
Postby ytechie » Thu Jan 19, 2012 5:01 am
Try changing it. Don't be afraid to play around with it a bit. Just remember what the settings were before you changed them.
ytechie
Re: port forwarding
Postby JFM » Thu Jan 19, 2012 1:13 pm
Thanks I tried out changing all the services for subsonic to public and it still didn't work for lan. I'll go into the advanced firewall setting and see what happens. Any other suggestions?
JFM
Re: port forwarding
Postby JFM » Sun Jan 22, 2012 3:23 am
Still not getting any in lan streaming. Have changed all services to public in windows 7 firewall and can't access it on lan except on the computer running the server itself.
JFM
Re: port forwarding
Postby ytechie » Sun Jan 22, 2012 3:51 am
Try turning off the firewall for a bit (not just setting the services to public).
ytechie
Re: port forwarding
Postby JFM » Mon Jan 23, 2012 4:58 pm
I will try that. Thanks.
JFM
Re: port forwarding
Postby BKKKPewsey » Mon Jan 23, 2012 6:13 pm
Exactly what address are you typing in to the other computers?
Are you using your myname.subsonic.org address?
Re: port forwarding
Postby patrickhenry » Wed Jun 27, 2012 2:23 am
JFM wrote:I can access subsonic outside of lan, but not on any other computer on the lan or wifi device for that matter. I have isub for my iphone and I switch to 3g and can stream all day, but nothing if I type in my address on any other machine in the house.
Same problem for me. Actually, I'm almost certain this is simply a networking issue, rather than something amiss with Subsonic, but here goes...
Can access Subsonic from the web browser running on the computer on which Susbsonic is installed. Can access Subsonic from my computer at work (over the WAN). Can access Subsonic from iSub so long as my phone is connected only by cellular.
Cannot access Subsonic from iSub when my phone is on the same LAN as the computer running Subsonic. Cannot access Subsonic from a web browser on the same LAN as the computer running Subsonic.
This is all new since earlier today, when I went away from using myname.subsonic.org to using the DynDNS service and port forwarding. The DynDNS-hosted URL is working for computers that are not on the LAN. To access Subsonic from off the LAN, I am entering myname.dyndns-remote.com:4040. That URL will not work when I am on the LAN.
What am I missing?
[system: iPhone with iSub for remote listening; server is Mac Mini (OS X Maverics) running Subsonic; Subsonic pointed at iTunes music folder stored on USB HDD]
patrickhenry
Re: port forwarding
Postby GJ51 » Wed Jun 27, 2012 3:10 am
Try using the local network address and port number.
192.168.1.XXX:4040
Does that work?
Re: port forwarding
Postby patrickhenry » Wed Jun 27, 2012 3:41 am
Initial research suggests that I need a feature called "loopback." However, it's not clear to me why my initial setup (http://myname.subsonic.org) was working, but my new setup (http://myname.dyndns-remote.com:4040) is not working.
patrickhenry
Re: port forwarding
Postby patrickhenry » Wed Jun 27, 2012 4:29 am
GJ51 wrote:Try using the local network address and port number.
192.168.1.XXX:4040
Does that work?
Thanks for your comment. I guess one thing I need to be more specific about, which may not have been clear - I primarily access Subsonic using iSub on my iPhone. However, the myname.dyndns-remote.com:4040 URL does not work when my iPhone is on the LAN.
Further to your comment, as a solution (workaround?), I now have two servers listed in the iSub server entries - the first is the myname.dyndns-remote.com:4040 server (works on WAN, not on LAN) and the second is the internal (LAN) IP address of the Subsonic host computer (192.168.1.xxx:4040). That seems to be working, and may be all that I can do given my router's lack of loopback support.
patrickhenry
Re: port forwarding
Postby GJ51 » Wed Jun 27, 2012 4:36 am
I agree, it sounds like the router's the problem. At least you now have a workaround.
