internal 404 error after installing
Postby jamz3243 » Thu Jan 19, 2012 4:09 am
Problem Description: I installed subsonic and when I go to localhost:4040 I get a 404 error with stuff
Troubleshooting Steps: I restarted the subsonic process and that is it.
Playback Application and version: n/a
Subsonic Version: subsonic-4.6
Server Version: not sure
Hardware Platform: xubuntu 11.10
Java Memory Limit: 100
Problem Filename: not sure
Output from ffmpeg -i: not installed
Last ten log file lines:
Exception   java.lang.NoClassDefFoundError
Message   net/sourceforge/subsonic/filter/ParameterDecodingFilter$DecodingServletRequestWrapper
Java version   Sun Microsystems Inc. 1.6.0_23
Operating system   Linux 3.0.0-14-generic
Server   jetty-6.1.x
Memory   Used 11 of 65 MB
Stack trace   java.lang.NoClassDefFoundError: net/sourceforge/subsonic/filter/ParameterDecodingFilter$DecodingServletRequestWrapper
   at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:51)
jamz3243
Re: internal 404 error after installing
Postby ytechie » Thu Jan 19, 2012 7:59 am
First thing I would do is a full reset of the host machine. Restarting the subsonic process doesn't always do the trick.
ytechie
