Problems with VISTA and Mediaplayer
Postby Gummiklokke » Mon Sep 03, 2007 8:14 pm
I have a problem, when i click "play all" or create a playlist - on my VISTA machine it plays the first song and then stops - seems like the Mediaplayer cant stream from subsonic?? Or see the next song.. - When i manually press play in the mediaplayer it continues to play from the playlist (the actual song in the playlist).. i have no problems on my XP machines..
Does it make any sence??
regards
Gummiklokke
Gummiklokke
Postby ProBlazer » Tue Sep 25, 2007 10:33 pm
i have experienced similar problems on my XP workstation with windows media player.
however it only does this for certain albums for some reason. but it's the same albums all the time.
ProBlazer
Postby abelour » Sat Nov 24, 2007 5:02 pm
I experience the same thing. I have to press play in windows mediaplayer after each song to start playing again.
Subsonic 3.3.beta1 (build 496)
Windows Vista
Windows mediaplayer
I don't think it is a Vista problem as I had the same problem under xp earlier. Unfortunately I don't remember the solution from last time....
abelour
Users browsing this forum: No registered users and 71 guests
