[Help] Little questions.
Postby Guizmo » Fri Jan 27, 2012 5:45 pm
To start with, I love your CMS. I'm not English, so there will probably be a few spelling mistakes and I might sometimes have difficulties understanding.
I have 2 problems :
- Why don't my albums appear on the home page ? http://d2.e-loader.net/NqKbT9VIFU.png
- Why doesn't the search engine work ? http://d10.e-loader.net/4SJ3jzK5YZ.png
I have 3 questions :
-How many online and actives users can I put in a hosted server with a 1.2GHz Atom, 2GB RAM, 1 TB Hard Drive in the even time ?
-How can I change the design ?
-How can I had the lyrics manually?
Thanks you in advance
Guizigui
Guizmo
Re: [Help] Little questions.
Postby bushman4 » Fri Jan 27, 2012 6:14 pm
As this is your first post, I removed the link to the unknown hosting provider and put the details of the plan instead...
As to your first two questions, run a search index up in the Settings->Search screen and both should work.
As to how many users you can support with that I can't really guess... if all of your music was already in MP3 (ie, no transcoding) then I would bet quite a few... 15 or 20 at a time would be my guess.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby BKKKPewsey » Fri Jan 27, 2012 6:28 pm
Guizmo wrote:I have 3 questions :
Your limitation will probably be with your internet upload speed - it depends how may users are trying to stream from you at same time.
Guizmo wrote:How can I change the design ?
Just change the theme or create your own if capable - see the modding section.
Guizmo wrote:How can I had the lyrics manually?
You can use any third party app to add lyrics to your ID tags - the problem is getting SS to display them.
I expect this is on Sindre's roadmap.
Edited: Because Glenn is a quicker typist then me :D
Postby Guizmo » Fri Jan 27, 2012 6:50 pm
First : Thanks a lot for your reactivity !
For my two problems it's good !! :D
For Kimsufi, it's OVH ! And OVH is the first of europe ! (isn't unknow), but no problem for me. If i understand 20 peoples it's good.
Don't understand :? Not possible for this moment ?
Two more questions :
- Not possible create a expiration date for a user ?
- It's possible to listen and download in FLAC ?
Thanks :P
Guizmo
Postby bushman4 » Fri Jan 27, 2012 6:57 pm
Not natively. A little scriupting and it may be possible to schedule a web request that would disable a user or change a password, but there is no native function for that.
Built in is the capability to transcode flac to MP3 to stream to the web client. It is also theoretically possible to stream native flac directly to an external player, but I don't have much experience with that. But yes, you can download the full untouched file if download rights are activated.
BTW, the only reason I editted your post it that we frequently have spammers come here and post mock questions with links in them to outside services that are not trustworthy. It was not a reflection of anything, just caution.
HTH,
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Guizmo » Fri Jan 27, 2012 8:19 pm
Other problem, on my subsonic, the rating system don't work.
Guizmo
Users browsing this forum: No registered users and 132 guests
