hidden player
hidden player
Postby Beowolf » Sat Jan 28, 2012 6:05 pm
In Ie i can watch videos
in FF and chrome the player is hidden up watds can only see jwplayer play and stream bar
ideas?
1,959 artists
1,970 albums
13,978 songs
941.65 GB (~ 14,628 hours)
Beowolf
Re: hidden player
Postby BKKKPewsey » Sat Jan 28, 2012 9:40 pm
Nope it all works fine for me - what theme are you using?
Re: hidden player
Postby Beowolf » Sun Jan 29, 2012 9:10 pm
tried them all still no difference
1,959 artists
1,970 albums
13,978 songs
Beowolf
Re: hidden player
Postby ytechie » Sun Jan 29, 2012 9:14 pm
Please post a screenshot. It would help a lot.
ytechie
Re: hidden player
Postby Beowolf » Mon Jan 30, 2012 10:58 pm
just a part of screen but u get the idea
1,959 artists
1,970 albums
13,978 songs
Beowolf
Re: hidden player
Postby ytechie » Mon Jan 30, 2012 11:58 pm
Wow. That's pretty bad. Try downloading the source version of subsonic and swapping the videoPlayer.jsp files.
ytechie
Re: hidden player
Postby Beowolf » Tue Jan 31, 2012 2:59 pm
So redownload, and just delete the jwplayer files and drop downloaded ones in?
i finally got the system running with everything other than player
1,959 artists
1,970 albums
13,978 songs
Beowolf
Re: hidden player
Postby ytechie » Tue Jan 31, 2012 3:49 pm
Don't replace the player. Replace the videoPlayer.jsp file.
ytechie
Re: hidden player
Postby Beowolf » Tue Jan 31, 2012 5:05 pm
ok so i saved DB, and then i reinstalled the SS and added the Outlook and bam same place issues,
if anyone can link me the zipped files, needed for the jwplayer and localion in c;/subsonic my lifewill be easier
1,959 artists
1,970 albums
13,978 songs
Beowolf
Re: hidden player
Postby ytechie » Tue Jan 31, 2012 5:37 pm
The JW player isn't broken unless you did something to the flash file or the embed js file.
ytechie
Re: hidden player
Postby BKKKPewsey » Tue Jan 31, 2012 5:38 pm
Your issue is with the Outllook mod rather then with SS so I suggest you ask for help in the relevant forum
viewtopic.php?f=8&t=7238
Re: hidden player
Postby Beowolf » Tue Jan 31, 2012 5:41 pm
BKKKPewsey wrote:Your issue is with the Outllook mod rather then with SS so I suggest you ask for help in the relevant forum
i was asking as tricky is moving with no internet, and i was hoping i would get some support from someone who knew
thanks
1,959 artists
1,970 albums
13,978 songs
Beowolf
Re: hidden player
Postby GJ51 » Tue Jan 31, 2012 8:01 pm
Your more likely to get some help on the Outlook theme thread in the Mods section.
I really like the Outlook theme and all the work that's been put into it, but keep in mind that any custom mods that haven't been rolled into a new release of SS are going to be a bear to redo when you upgrade to the next version of SS. If you have multiple servers and multiple instances of SS to play around with and experiment you can learn a lot about what's under the hood in SS and have a lot of fun, but I wouldn't get too carried away if you're a bit of a newbie to SS and you only have one SS instance to work with that you want to depend on for day-to-day use.
Re: hidden player
Postby Beowolf » Mon Feb 13, 2012 6:43 pm
ahem?
1,959 artists
1,970 albums
13,978 songs
Beowolf
Users browsing this forum: No registered users and 262 guests
