Not able to use ******.subsonic.org to access my server
Postby irishgond » Sat Jan 28, 2012 7:40 pm
On the networking settings there is an option to access your server externally using an "easy to remember" address.
I keep getting this when trying to use it:
Status: irishgond.subsonic.org is registered, but could not connect to it. (SocketException)
I use iSub and that is working just fine externally. It also is working just fine when I use my IP and port... **.**.**.**:8080
So, port is forwarded and all working just not able to access using the resolved address...
irishgond
Re: Not able to use ******.subsonic.org to access my server
Postby Beowolf » Sat Jan 28, 2012 8:22 pm
hey i am not an expert i looked from my end can not see, seems no web is running
do you have appache or something webserver running?
i also improved my response time by installing flash and java on my server
1,959 artists
1,970 albums
13,978 songs
941.65 GB (~ 14,628 hours)
Beowolf
Postby alphawave7 » Sun Jan 29, 2012 8:25 am
irishgond wrote:On the networking settings there is an option to access your server externally using an "easy to remember" address.
Your IP has changed...click 'Save' to in that same window to update the .org server with the new IP. :)
