My new transcode settings don't seem to be working
Postby Impyy » Sun Jan 29, 2012 9:41 pm
My entire music collection is in FLAC. I wish to stream my collection as V0 .mp3s so I set up the command lines like so:
Convert from: flac
Step 1: flac --decode -F --stdout %s
Step 2: lame -V 0 --vbr-new --ignore-tag-errors - -
This however doesn't seem to work as when I try to play a track it loads the song then doesn't play and will skip to next song in playlist, load that song, won't play and then load the next. So on, so on.
I have the latest LAME encoder inside the correct folder within where Subsonic is located on my computer. What gives? :(
Impyy
Re: My new transcode settings don't seem to be working
Postby ytechie » Sun Jan 29, 2012 9:46 pm
I don't know if this will fix the problem, but you have to add a hyphen (-) to the end of each step. Here is what it should look like:
Step 1: flac --decode -F --stdout %s -
ytechie
Postby Impyy » Sun Jan 29, 2012 9:53 pm
Still nothing. It just loads the song to 100% then skips it altogether and loads the next song. These are my newly updated settings:
Convert from: flac
Convert to: mp3
Step 2: lame -V 2 --vbr-new --ignore-tag-errors -
Impyy
Postby ytechie » Sun Jan 29, 2012 9:54 pm
What player are you using?
ytechie
Postby ytechie » Sun Jan 29, 2012 9:57 pm
I just tried the settings, and it works in the web player.
I used these settings:
ytechie
Postby Impyy » Sun Jan 29, 2012 9:58 pm
I'm not quite sure what you mean. It's the web player.
Impyy
Postby ytechie » Sun Jan 29, 2012 10:00 pm
OK. Try copying and pasting the transcode settings from my previous post. I added a hyphen.
ytechie
Postby Impyy » Sun Jan 29, 2012 10:01 pm
My Internet at this place is extremely slow. Loading a song now with those exact command lines.
EDIT: Nope. Just loads then doesn't play and skips to next and does it allover again.
Convert from: flac
Convert to: mp3
Impyy
Postby Impyy » Sun Jan 29, 2012 10:03 pm
How annoying.
Impyy
Postby ytechie » Sun Jan 29, 2012 10:04 pm
That's really odd. I am streaming flacs using those exact settings, and it's working fine. What version of subsonic are you using?
ytechie
Postby Impyy » Sun Jan 29, 2012 10:06 pm
Hmm. :/ Is there anything else I needed to do on my computer? All I did was get the latest lame.exe and drop it in the correct folder.
4.6 (build 2583) – December 6, 2011
Impyy
Postby ytechie » Sun Jan 29, 2012 10:06 pm
Can you post the log output? Let's see where the problem is.
ytechie
Postby Impyy » Sun Jan 29, 2012 10:10 pm
[1/29/12 9:48:06 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Into You' for user DominicRead at Last.fm.
[1/29/12 9:48:50 PM GMT] DEBUG AudioScrobblerService Successfully registered submission for song 'Into You' for user DominicRead at Last.fm.
[1/29/12 9:48:50 PM GMT] INFO PlaylistInputStream admin listening to "The Cinematic Orchestra - 2007 - Ma Fleur\09 Breathe.flac"
[1/29/12 9:48:50 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Breathe' for user DominicRead at Last.fm.
[1/29/12 9:48:57 PM GMT] INFO StreamController Got range: Range[5509248,9223372036854775807]
[1/29/12 9:48:57 PM GMT] INFO PlaylistInputStream admin listening to "Young Fathers - 2011 - Tape One [WEB - 24bit]\01 Deadline.flac"
[1/29/12 9:48:57 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Deadline' for user DominicRead at Last.fm.
[1/29/12 9:49:35 PM GMT] INFO PlaylistInputStream admin listening to "The Low End Theory\01 Excursions.flac"
[1/29/12 9:49:36 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Excursions' for user DominicRead at Last.fm.
[1/29/12 9:49:36 PM GMT] DEBUG AudioScrobblerService Successfully registered submission for song 'Deadline' for user DominicRead at Last.fm.
[1/29/12 9:50:01 PM GMT] INFO PlaylistInputStream admin listening to "Cloud Nothings - 2012 - Attack on Memory\01 No FutureNo Past.flac"
[1/29/12 9:50:01 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'No Future/No Past' for user DominicRead at Last.fm.
[1/29/12 9:51:41 PM GMT] INFO PlaylistInputStream admin listening to "Cloud Nothings - 2012 - Attack on Memory\02 Wasted Days.flac"
[1/29/12 9:51:41 PM GMT] DEBUG AudioScrobblerService Successfully registered submission for song 'No Future/No Past' for user DominicRead at Last.fm.
[1/29/12 9:51:41 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Wasted Days' for user DominicRead at Last.fm.
[1/29/12 9:51:43 PM GMT] INFO PlaylistInputStream admin listening to "Cloud Nothings - 2012 - Attack on Memory\01 No FutureNo Past.flac"
[1/29/12 9:51:43 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'No Future/No Past' for user DominicRead at Last.fm.
[1/29/12 9:51:59 PM GMT] INFO StreamController Got range: Range[691008,9223372036854775807]
[1/29/12 9:51:59 PM GMT] INFO PlaylistInputStream admin listening to "Cloud Nothings - 2012 - Attack on Memory\02 Wasted Days.flac"
[1/29/12 9:51:59 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Wasted Days' for user DominicRead at Last.fm.
[1/29/12 9:52:27 PM GMT] INFO StreamController Got range: Range[3514368,9223372036854775807]
[1/29/12 9:52:27 PM GMT] INFO PlaylistInputStream admin listening to "Cloud Nothings - 2012 - Attack on Memory\01 No FutureNo Past.flac"
[1/29/12 9:52:27 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'No Future/No Past' for user DominicRead at Last.fm.
[1/29/12 9:52:27 PM GMT] DEBUG AudioScrobblerService Successfully registered submission for song 'Wasted Days' for user DominicRead at Last.fm.
[1/29/12 9:53:45 PM GMT] DEBUG AudioScrobblerService Successfully registered submission for song 'No Future/No Past' for user DominicRead at Last.fm.
[1/29/12 9:53:45 PM GMT] INFO StreamController Got range: Range[7450624,9223372036854775807]
[1/29/12 9:53:45 PM GMT] INFO PlaylistInputStream admin listening to "Cloud Nothings - 2012 - Attack on Memory\02 Wasted Days.flac"
[1/29/12 9:53:45 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Wasted Days' for user DominicRead at Last.fm.
[1/29/12 9:54:44 PM GMT] INFO PlaylistInputStream admin listening to "James Blake - 2011 - James Blake\01 Unluck.flac"
[1/29/12 9:54:44 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Unluck' for user DominicRead at Last.fm.
[1/29/12 9:54:45 PM GMT] DEBUG AudioScrobblerService Successfully registered submission for song 'Wasted Days' for user DominicRead at Last.fm.
[1/29/12 9:58:47 PM GMT] INFO StreamController Got range: Range[2433024,9223372036854775807]
[1/29/12 9:58:47 PM GMT] INFO PlaylistInputStream admin listening to "James Blake - 2011 - James Blake\01 Unluck.flac"
[1/29/12 9:58:47 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Unluck' for user DominicRead at Last.fm.
[1/29/12 9:59:29 PM GMT] INFO PlaylistInputStream admin listening to "James Blake - 2011 - James Blake\02 The Wilhelm Scream.flac"
[1/29/12 9:59:29 PM GMT] DEBUG AudioScrobblerService Successfully registered submission for song 'Unluck' for user DominicRead at Last.fm.
[1/29/12 9:59:29 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'The Wilhelm Scream' for user DominicRead at Last.fm.
[1/29/12 9:59:55 PM GMT] INFO PlaylistInputStream admin listening to "James Blake - 2011 - James Blake\01 Unluck.flac"
[1/29/12 9:59:55 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Unluck' for user DominicRead at Last.fm.
[1/29/12 10:00:06 PM GMT] DEBUG AudioScrobblerService Successfully registered submission for song 'Unluck' for user DominicRead at Last.fm.
[1/29/12 10:00:47 PM GMT] INFO PlaylistInputStream admin listening to "Cloud Nothings - 2012 - Attack on Memory\01 No FutureNo Past.flac"
[1/29/12 10:00:48 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'No Future/No Past' for user DominicRead at Last.fm.
[1/29/12 10:02:20 PM GMT] INFO StreamController Got range: Range[22955104,9223372036854775807]
[1/29/12 10:02:20 PM GMT] DEBUG AudioScrobblerService Successfully registered submission for song 'No Future/No Past' for user DominicRead at Last.fm.
[1/29/12 10:02:20 PM GMT] INFO PlaylistInputStream admin listening to "Cloud Nothings - 2012 - Attack on Memory\02 Wasted Days.flac"
[1/29/12 10:02:20 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Wasted Days' for user DominicRead at Last.fm.
[1/29/12 10:05:02 PM GMT] DEBUG AudioScrobblerService Successfully registered submission for song 'Wasted Days' for user DominicRead at Last.fm.
[1/29/12 10:08:30 PM GMT] INFO PlaylistInputStream admin listening to "Cloud Nothings - 2012 - Attack on Memory\03 Fall In.flac"
[1/29/12 10:08:30 PM GMT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Fall In' for user DominicRead at Last.fm.
[1/29/12 10:08:44 PM GMT] DEBUG AudioScrobblerService Successfully registered submission for song 'Fall In' for user DominicRead at Last.fm
That's everything in the log window.
Impyy
Postby ytechie » Sun Jan 29, 2012 10:18 pm
I don't know why subsonic thinks you are trying to stream only a range. I am looking at the source code, but I don't know enough about file formats to fully understand what might be going on here. :?
ytechie
Postby Impyy » Sun Jan 29, 2012 10:22 pm
What does range mean? Oh this is so fustrating. :(
Impyy
