Embedded flash player occasionally stops playback
Postby gav » Tue Jan 31, 2012 1:04 pm
I've been using Subsonic for a while now (~6 months), and I've had an intermittent issue with playback using the embedded flash player. Every now and then playback will just stop and that particular Subsonic player from that point onwards will always stop at the same point in the song. The only workaround that I've figured out so far is to create another player in Subsonic - this will then play the song fine.
I suspect that the track for which playback stops I may have pressed "skip" before the track had fully downloaded, or something similar, but I cannot systematically reproduce it.
For reference I'm using Chrome on XP, and Subsonic 4.6 (build 2585) running on Ubuntu.
Many thanks,
Gavin
gav
Re: Embedded flash player occasionally stops playback
Postby GJ51 » Wed Feb 01, 2012 4:04 am
If it happens again, look at the log for clues,
