recommended Java version?
Postby jol » Sat Feb 04, 2012 7:17 pm
when I installed Subsonic 4.6, the installation automatically pulled also Java in version 1.6 (1.6.0_27-b07, 32bit). Subsonic works just fine, however Java complains about being outdated. There are multiple newer versions (listed on http://www.oracle.com/technetwork/java/javase/index.html): Java 6 1.6.0_30, Java 7 update 2, and if you look in depth, both come in 32 and 64 bit versions. I guess the update will just go for 1.6.0_30 and stick to 32bit, but would you recommend any of the other versions? Does Java 7 perform better with Subsonic? Will Subsonic automatically use a better version?
Thanks, jol
Subsonic 4.7 running on Acer H340 with LDAP authentication / Windows Home Server 2011 - Android client (3.5)
jol
Re: recommended Java version?
Postby GJ51 » Sun Feb 05, 2012 8:41 am
I've never had any problems using the latest versions from here:
http://www.java.com/en/download/manual.jsp
Java 7 is not yet recomended for end users:
http://www.java.com/en/download/faq/java7.xml
Postby jol » Sun Feb 05, 2012 12:36 pm
GJ51 wrote:Java 7 is not yet recomended for end users:
Thanks, this reduces the question to 32 vs. 64 bit - what do you recommend? I am not using the browser on my server, thus the question is only what fits better to Subsonic.
Thanks, jol
jol
Postby GJ51 » Sun Feb 05, 2012 2:54 pm
You only meed to install the 64 bit version if you use a 64 bit browser sich as IE 64 bit. You shouldn't need it on the server.
